Max/Min not found on plot
07-14-2019, 04:46 PM
I plotted the 2nd derivative of e^(1/4). The function plots nicely on my G2, but when querying for obvious extremums on the plot between -1 and 0, no maximum or minimum is found. This occasionally surprises me on other plots as well. Why is this (operator ignorance?)?
07-14-2019, 06:57 PM
RE: Max/Min not found on plot | |||
07-14-2019, 07:19 PM
Your e^(1/x) assumption was correct. I get the same graph, but it does not find the extremums. Might I have some setting that is causing this? This is not an artifact of the G2...my version A does this as well. I must have a CAS setting or home setting that needs to be changed?
07-14-2019, 07:22 PM
I am using the default epsilon of 1e-12, have it on exact, tried 1e-14, non exact, same lack of extremum. Aug 2018 version on G2, July 2018 on version A.
07-14-2019, 07:28 PM
07-14-2019, 07:33 PM
Same as me...on plot, my setting is adaptive...
07-15-2019, 11:03 AM
My plot method is also set to adaptive.
-road |
01-05-2022, 02:14 AM
(This post was last modified: 01-05-2022 02:16 AM by jte.)
The plotting method does not affect extrema (or root) finding.
User(s) browsing this thread:
