(48G/GX) DIRSTAT - Find RAM Hogs
05-16-2014, 05:43 PM
As the name suggests, this is a clone of programs like WinDirStat/KDirStat. Run it to see the sizes of all variables and subdirectories in the current directory, sorted in descending order of size. You can then navigate to other directories by selecting them and pressing ENTER (then waiting for the program to rebuild the list). There's a lot of G/GX-specific stuff here, so it's not compatible with the S/SX without heavy modification. The installed size is 481 bytes.
This also requires CHOOSF, which is a drop-in full-screen replacement for CHOOSE. You can either get CHOOSF from this old Usenet posting, or just download the 48G/GX version attached to this post. The installed size of CHOOSF is only 109.5 bytes. Definitely worth having around if you use CHOOSE at all. Code: %%HP: T(3)A(D)F(.); CHOOSF.zip (Size: 216 bytes / Downloads: 6) |
05-18-2014, 10:23 AM
RE: (48G/GX) DIRSTAT - Find RAM Hogs
Google is NOT usenet. For anybody posting usenet links, would you please include the usenet message-id field? That way we can find the post(s) via a regular usenet (NNTP) reader. Many of us do not use google.
No offense intended to Dave, whose presence here is much appreciated It ain't OVER 'till it's 2 PICK |
05-18-2014, 07:56 PM
(This post was last modified: 05-18-2014 07:59 PM by Dave Britten.)
Duly noted. Here's the whole message for anybody that wants it. I've only ever been a casual user of Usenet.
Code: Path: g2news1.google.com!news2.google.com!fu-berlin.de!uni-berlin.de!individual.net!not-for-mail |
05-19-2014, 05:43 AM
Thank you, sir.
The line that says Code: Message-ID: <op.s6uwagnowmwqgg@news.cis.dfn.de> is the "usenet message id." If you have a good newsreader you can actually paste or type that in and it will send a command to whatever server(s) you are connected to and pull up the exact post if it's still being retained. And all of this with no participation of google. Admittedly google does have an edge in retention since they vacuum up all stray bits on the net at taxpayer expense... It ain't OVER 'till it's 2 PICK |
05-19-2014, 09:58 AM
(05-19-2014 05:43 AM)HP67 Wrote: Thank you, sir. Yeah, I was trying to get just that line, but copy/paste in iPad Safari very frequently falls on its face and prevents selecting only very specific parts of text, so I had to grab the whole thing. For a company so obsessed with interface polish and usability, Apple does have a tendency to leave some really irritating UI bugs languishing for years. |
