(41CV) Planning Fuel-Conservative Descents
07-19-2019, 12:30 PM
An extract from Planning Fuel Conservative Descents in an Airline Environment Using a Small Programmable Calculator, NASA, Scientific & Technical Information Branch, Technical Paper 2393, May-1985 (84 pgs.)
Summary … An investigation into the feasibility of using the open-loop guidance in an airline operational environment was conducted. The algorithm was programmed on a small programmable calculator for use with … A version of the flight-management descent algorithm was implemented on a Hewlett-Packard HP-41CV programmable calculator. Open-loop guidance was provided by the calculator … This report contains a description of the programmable calculator software, the … performance model used in the algorithm computations, and the results of the model-validation and pilot-evaluation flight tests. … Appendix A--Program Flow Chart Appendix B--Calculator Program Descriptions, explanations, diagrams, equations, tables, illustrations, figures, flowcharts, listings etc.; thoroughly documented! Best! SlideRule |
07-22-2019, 05:08 AM
(This post was last modified: 07-22-2019 05:08 AM by Ángel Martin.)
RE: (41CV) Planning Fuel-Conservative Descents
(07-19-2019 12:30 PM)SlideRule Wrote: An extract from Planning Fuel Conservative Descents in an Airline Environment Using a Small Programmable Calculator, NASA, Scientific & Technical Information Branch, Technical Paper 2393, May-1985 (84 pgs.) This one is a real beauty, you're unearthing real jewels with your findings, many thanks again! ÁM "To live or die by your own sword one must first learn to wield it aptly." |
08-30-2019, 05:14 AM
Now available in the [NASA] module from the CL Library.
