Funny Factorials and Slick Sums
08-05-2019, 12:21 AM (This post was last modified: 08-19-2020 11:54 AM by Albert Chan.)
Spring 2017 ARML Power Contest, Problems and Solutions.
Example, find s6(n) = Σ(x^6, x = 0 to n-1)
Convert x^6 to falling factorial form, where xn = product(x-k, k = 0 .. n-1)
Synthetic Division, polynomial to falling factorial form:
   1  0  0  0  0  0  0  // x^6
1> 1  1  1  1  1  1     // = (x-1)(x^5 + x^4 + x^3 + x^2 + 1) + 1
2> 1  3  7 15 31
3> 1  6 25 90
4> 1 10 65
5> 1 15
Note: synthetic divide by (x-0) step skipped, since x^6 = (x-0)*x^5 + 0
x^6 = x6 + 15 x5 + 65 x4 + 90 x3 + 31 x2 + x1
From problem 12, Σ(xm, x=0 to n-1) = nm+1 / (m+1)
s6(n) = n7/7 + 15 n6/6 + 65 n5/5 + 90 n4/4 + 31 n3/3 + n2/2
After simplify, s6(n) = n^7/7 - n^6/2 + n^5/2 - n^3/6 + n/42
http://www.arml.com/ had more contests. 2009-2014 contests book is free to download.
08-05-2019, 03:06 PM (This post was last modified: 08-07-2019 12:39 PM by Albert Chan.)
RE: Funny Factorials and Slick Sums
(08-05-2019 12:21 AM)Albert Chan Wrote:  s6(n) = n7/7 + 15 n6/6 + 65 n5/5 + 90 n4/4 + 31 n3/3 + n2/2
We can automate the process of simplifying.
For s6(n), polynomial linear coefficent = limit(s6(n)/n, n=0):
(-1)6/7 + 15 (-1)5/6 + 65 (-1)4/5 + 90 (-1)3/4 + 31 (-1)2/3 + (-1)1/2
= -1*(1/2 - 2*(31/3 - 3*(90/4 - 4*(65/5 - 5*(15/6 - 6*(1/7))))))
= -1*(1/2 - 2*(31/3 - 3*(90/4 - 4*(65/5 - 5*(23/14)))))
= -1*(1/2 - 2*(31/3 - 3*(90/4 - 4*(67/14))))
= -1*(1/2 - 2*(31/3 - 3*(47/14)))
= -1*(1/2 - 2*(11/42))
= -1*(-1/42)
= 1/42
→ s6(n) / n = (1/7) n6 + (23/14) n5 + (67/14) n4 + (47/14) n3 + (11/42) n2 + (-1/42) n1 + 1/42
We divide n repeatedly, collecting remainder terms, until quotient is linear, since a n1 + b n0 = a n + b
Synthetic Division, falling factorial form to polynomial
      6 105 546 945 434  21   0   0  // 42*s6, falling factorial coefficients
-6 0> 6  69 201 141  11  -1   1      // -6*6+105=69, -5*69+546=201 ...
-5 0> 6  39  45   6  -1   0          // -5*6+69=39, -4*39+201=45 ...
-4 0> 6  15   0   6  -7
-3 0> 6  -3   6   0
-2 0> 6 -15  21
-1 0> 6 -21
Note: 0> signalled first column numbers treated as stack, "popped" when used.
→ s6(n) = (6 n^7 - 21 n^6 + 21 n^5 - 7 n^3 + n) / 42
see threads: Bernoulli Numbers, Sum of Powers
08-07-2019, 01:57 PM (This post was last modified: 08-08-2019 12:41 PM by Albert Chan.)
We can generalize falling factorial form polynomial and power form polynomial as Newton form polynomial.
For falling factorial form, offsets = 0,1,2,3, ...
For power form, offsets = 0,0,0,0, ...
Below is the synthetic division, that can convert from 1 set of offsets, to another.
Example: simplify this: S4(n) = -17 + \(16\binom{n+3}{1}-15\binom{n+3}{2}+14 \binom{n+3}{3}-12\binom{n+3}{4}+24\binom{n+3}{5}\)
To setup synthetic division, negate the from-offsets, and put to first column, in reverse order.
For above S4(n), negated from-offsets = 3,2,1,0,-1
Next, put to-offsets to second column.
Since S4(-1) = S4(0) = 0, we know S4(n) has factor n*(n+1), thus to-offsets = -1,0,0,0,0
For each row, to-offset numbers is "locked". Negated from-offsets treated like a stack, "popped" when used.
        24  -12   14  -15   16  -17 // S4 in binomial form
         6  -15   70 -225  480 -510 // 30*S4 in falling factorial form
-1 -1>   6  -27   97 -225  255    0 // (-1-1)*6-15=-27, (0-1)*-27+70=97, (1-1)*97-225=-225 ...
 0  0>   6  -27   70  -85    0      // (0+0)*6-27=-27, (1+0)*-27+97=70, (2+0)*70-225=-85 ...
 1  0>   6  -21   28   -1
 2  0>   6   -9    1
 3  0>   6    9
6n³ + 9n² + n - 1 = (2n+1) (3n² + 3n - 1)
→ S4(n) = (n)(n+1)(2n+1)(3n² + 3n - 1) / 30
source: "Fundamentals of Numerical Anaylsis" by Stephen G. Kellison, published in 1975
Appendix B: Transformation of polynomial forms. (modified to use only +* for synthetic division)
08-07-2019, 04:45 PM
I love this.
Quote:WARNING! In several of the problems, you may be tempted touse an ellipsis (“. . . ”) to shorten arguments or to indicate that apattern continues. DO NOT do this. All proofs must be complete.Ellipsis probably means you need to use induction or recursion
11-02-2021, 02:59 PM
(08-05-2019 12:21 AM)Albert Chan Wrote:  From problem 12, Σ(xm, x=0 to n-1) = nm+1 / (m+1)
We can extend this to negative integer powers (but, m≠-1)
Note that xm = perm(x,m) = x / (x-m)!       (*)
Cas> lfac(x,m) := factor(simplify(x!/(x-m)!))
Cas> lfac(x,3)       → x*(x-1)*(x-2)
Cas> ifac(x,0)       → 1
Cas> ifac(x,-3)      → 1/((x+1)*(x+2)*(x+3))
Issues to watch out for.
1). just like ∫(1/x,x=1..n) = ln(n), quoted formula does not work for m == -1
Note: Psi(n+1) = 1/n + Psi(n) = Hn + Psi(1) = Hn - euler_gamma
Cas> sum(lfac(x,-1), x=0..n-1)       → Psi(n+1) + euler_gamma
2). Other negative integer powers, we have to evaluate for lower limit.
Note: "!" has higher precedence than unary minus, parentheses necessary.
m<-1 : 0 m+1 / (m+1) = 1/(-(m+1))!/(m+1)
Example:
Cas> m := -3
Cas> s1 := sum(lfac(x,m), x=0..n-1)
1/4 + 1/(2*n+2) + 1/(2*n+4) + 1/(-n-1)
Cas> s2 := lfac(n,m+1)/(m+1) - 1/(-(m+1))!/(m+1)
1/4 − 1/2/((n+1)*(n+2))
Cas> simplify(s1-s2)
0
(*) not quite. Numerical version for negative m not yet implemented.
Cas> perm(x,-3)       → x!/(x+3)!
Cas> perm(0,-3)       → 0 // should be 1/6
