(HP-67/97) Antenna Polar Pattern
08-17-2019, 02:44 PM
The following extract HP-67/97 program plots antenna's polar pattern was previously referenced in HP 41 Polar Plots? (12-21-2013).
"Computing the radiation pattern of driven antenna arrays in polar form is easy with this HP-67/97 program. Given the relative spacing, phasing, and orientation of a multielement array having parallel or colinear half-wave elements in the horizontal plane, the routine tabulates the power gain of the array as a function of the incremental compass angle specified by the user." BEST! Slide |
