(15C) Buffon's Needle
09-08-2019, 03:57 PM
(This post was last modified: 09-08-2019 04:01 PM by SlideRule.)
An extract from Buffon, [kiyoshiakima url]
"2 Simulation Programs Buffon's Needle can be implemented easily on all but the smallest HP programmable calculators (the HP-16 and the financial models will need an implementation of the sine function). 2.1 RPN Some of the earlier machines did not have a built-in RNG (random number generator). One can be programmed, of course, but that requires additional memory. In addition, the HP-25A/C and HP-33E/C don't have enough memory registers unless one packs multiple results into each register (which requires additional code). The program given here is written for the HP-15C. It takes advantage of the built-in RNG and the capability to DSE any register. Every other model lacks one or both of these capabilities, though neither one by itself takes much programming effort to overcome." BEST! SlideRule |
