HP 34S: Find an element in a matrix?
05-22-2014, 05:36 AM
Can someone please explain the syntax/function of MFD?
I need to find a given matrix element to implement Shanks square form factorization method.
05-22-2014, 06:10 AM
RE: HP 34S: Find an element in a matrix?
From the code I'd say: ( y mat -> r )
Where mat is a matrix descriptor and y is the element you search.
/* Find a specified element in a matrix
            LBL'MFD'
            ABS
            M-ALL
            x[<->] Y
m_find_loop::       x=?[->]Y
            JMP m_found
            ISG Y
            JMP m_find_loop
m_found::       DROP
            RTN
05-22-2014, 06:51 AM
To post #2:
Thank you.
I don't understand r.
For 5,6,7,8 stored in registers 20 to 23
stack y: 55 x: 20.0401 returns 24.02301
and
stack y: 7 x: 20.0401 returns 22.02301
Presumably the second result indicates "found"? How should this result be interpreted?
05-22-2014, 07:10 AM
You probably want the index of the element. The matrix descriptor is still in the last x register. Therefore you can use:
RCL L
M.IJ
For 7 you get (x, y) = (3, 1). For 55 you get an Error: Out of range.
05-22-2014, 07:33 AM
To post #4:
Thank you & yes that is the info I needed.
Will now get to work on Shanks SQFF.
