How to evaluate a function in a given point
10-05-2019, 02:54 PM
Hello everyone,
I have just acquired my HP Prime, and this weekend I decided to spend some time learning how to implement some basic numeric methods on it.
While doing so with Regula Falsi, despite my code is apparently correct, I am continuously being given the message 'Incorrect argument type' when running it on my device. You can find it attached below:
EXPORT REGULA_FALSI()
LOCAL n,a,b,xnew,tol,N,f;
N := 100;
tol := .001;
IF INPUT(
{{f,[8]},{a,[0]},{b,[0]},{tol,[0]},{N,[0,1]}},
"Regula falsi's method",
{"f(X)=", "Left guess=", "Right guess=", "Tolerance=", "Max iter.="},
"Enter the function surrounded by single quotes",
"Enter the initial left guess",
"Enter the initial right guess",
"Enter the tolerance",
"Enter the maximum number of iterations"
{f,a,b,tol,N}
) THEN
F0 := expr(f);
L1 := {};
L1(1) := a;
FOR n from 2 to N+1 DO
xnew := a - F0(a)*(b-a)/(F0(b)-F0(a));
IF F0(a)*F0(xnew) < 0
THEN b := xnew;
ELSE a := xnew;
L1(n) := xnew;
IF F0(a) < tol
THEN BREAK;
editlist(L1);
Do you have any clue about why isn't it correct?
Thank you so much in a advance, and may you have a nice day.
With kind regards,
Aitor
10-06-2019, 06:06 AM (This post was last modified: 10-06-2019 06:09 AM by Tyann.)
RE: How to evaluate a function in a given point
Bonjour
Le problème semble venir de F0 qui si j'ai bien compris doit contenir la fonction entrée dans f.
Je vous propose les modifications suivantes :
IF INPUT({f,[8]},..... <-> IF INPUT({f,[2]},......
F0:=expr(f); <-> F0:=f;
Suite à ces corrections je n'obtiens plus d'erreur d'argument.
Espérant avoir pu vous aider.
Hello
The problem seems to come from F0 which if I understood correctly must contain the function entered in f.
I propose the following changes:
Following these corrections I no longer get an argument error.
Hoping to have been able to help you.
Sorry for my english
