(12C) Finding Two Factors Close to N
10-20-2019, 03:10 PM
Introduction
This program finds two factors of the integer N, where one of the factors is close to, but not equal to √N as possible. Let X and Y be positive integers where: (I) N = B^2 - A^2 By the difference of squares: (II) N = (B - A) * (B + A) The program tests every integer higher than √N. Let B = int(√N) + 1. If A = N - B^2 is an integer, the search stops. The program uses the equation (II) above and places the results on the stack as such: Y Stack: B + A // the program pauses to show this result X Stack: B - A Code:
Examples: n = 22356 = 162 * 138 n = 667 = 29 * 23 n = 4120 = 206 * 20 n = 144 = 18 * 8 (remember, factors close to √n as possible, but not the square root) n = 97 = 97 * 1 (prime number) Blog post: http://edspi31415.blogspot.com/2019/10/h...teger.html |
10-20-2019, 11:02 PM
RE: (12C) Finding Two Factors Close to N
(10-20-2019 03:10 PM)Eddie W. Shore Wrote: N = (B - A) * (B + A) I think you meant the program test integer C = A+B, A+B+1, A+B+2, ... If C^2 - N is a square, then stop Using your example, N = 22356 C = int(√N) + 1 = 150 C^2 - N = 144 = 12^2 → N = 150^2 - 12^2 = (150 + 12) * (150 - 12) = 162 * 138 Thomas Kleem also posted Fermat Factorization code for HP-12C, but only for odd N https://www.hpmuseum.org/forum/thread-11...#pid103729 |
