Garbage names in the cas vars menu
10-23-2019, 02:26 PM (This post was last modified: 10-24-2019 10:20 AM by rombva.)
I wrote the program for the cas mode.
#cas
zf74(X,Y,γ,a,b):=
LOCAL f,v;
PRINT("---------------------------------");
PRINT("W#7, P#4:");
γ:=unapply(γ,x);
X:=unapply(X,{x,y});
Y:=unapply(Y,{x,y});
f:=expand(simplify(subst(X(x,y)+Y(x,y)*diff(γ(x),x),y=γ(x))));
PRINT("f(x)="+f+";");
PRINT("F(x)="+expand(simplify(∫(f,x)))+";");
v:=∫(f,x,a[1],b[1]);
PRINT(suppress("∫(f(x)"," ")+", x, "+a[1]+", "+b[1]+")="+v+when(FP(v)≠0,"="+ROUND(v,4),"")+";");
1;
#end
After a lot of runs in the CAS Vars menu the garbage or/and empty-names variables appear. This issue happens while running my other cas programs.
Command line:
[Image: 7rd27zF9FJ.png]
Before running:
[Image: v51afl7w10.png]
After running:
[Image: F3A2wTINS4.png]
CAS Vars mem:
[Image: Bywhn1K4cc.png]
10-24-2019, 07:04 AM
RE: Garbage names in the cas vars menu
This on a calculator, emulator, etc?
TW
10-24-2019, 09:39 AM
(10-24-2019 07:04 AM)Tim Wessman Wrote:  This on a calculator, emulator, etc?
On a calculator (G2) and emulators (Win10, Android). Sometimes the run returns the input line without showing a terminal window.
10-24-2019, 10:06 AM
I'd like to try and reproduce, but you have conveniently hidden your inputs in the screenshot. Smile I see: zf74(2*x-y,-x*y,<--hidden by box---->,[2,8])
Can you copy the command line of your run in? Thanks. Also, give it a whirl on the latest 1.5.0 CAS version if you want.
TW
10-24-2019, 10:23 AM
(10-24-2019 10:06 AM)Tim Wessman Wrote:  I'd like to try and reproduce, but you have conveniently hidden your inputs in the screenshot. Smile I see: zf74(2*x-y,-x*y,<--hidden by box---->,[2,8])
Sorry. Command line: zf74(2*x-y,-x*y,2*x^2,[0,0],[2,8]).
10-24-2019, 10:46 AM (This post was last modified: 10-24-2019 10:47 AM by rombva.)
(10-24-2019 10:06 AM)Tim Wessman Wrote:  ...
On the beta emu (Windows, x64):
Run 01:
[Image: T89z58ITKC.png]
Run 02:
[Image: 39yClcbPl0.png]
Run 03:
[Image: kOLB3vgGGs.png]
Run 04:
[Image: V16c2rUKhO.png]
Run 05:
[Image: 8jPv5vmLRA.png]
Run 06:
[Image: 1gVcL73mU5.png]
Run 07:
[Image: 2chuRzUHJG.png]
Run 08:
[Image: 7PnVZb3Q4I.png]
Run 09:
[Image: eXlZjAYPMB.png]
Run 10:
[Image: qGM0L6pbnX.png]
10-24-2019, 01:19 PM
Thanks! Will investigate....
TW
10-24-2019, 09:58 PM
On my Android Emu changing "∫" to "int" in line
PHP Code:
// v:=∫(f,x,a[1],b[1]);
v:=int(f,x,a[1],b[1]);
avoided mem garbage generation. Maybe helps also in your case?
10-24-2019, 10:41 PM
This error also happened in XCAS see discussion
https://xcas.univ-grenoble-alpes.fr/foru...ile#p10348
10-25-2019, 03:41 AM
(10-24-2019 09:58 PM)FrankP Wrote:  On my Android Emu changing "∫" to "int" in line
PHP Code:
That's right, thanks.
But after running the program in the cas vars menu the x variable with assumption of integration boundaries appears.
[Image: 7aIhL3J8yZ.png]
[Image: R3bj7l4VV1.png]
10-25-2019, 06:00 AM
That's expected, because x is not declared as a local variable (add purge(x) after declaration to keep it symbolic).
10-25-2019, 08:47 AM
(10-25-2019 06:00 AM)parisse Wrote:  That's expected, because x is not declared as a local variable (add purge(x) after declaration to keep it symbolic).
Thanks!
10-28-2019, 01:30 AM
Thanks!
So just to clarify, when you changed to "int(...)" the problem basically when away? (letting us focus on the ∫(...) path exclusively to track it down)
TW
10-28-2019, 05:30 AM
(10-28-2019 01:30 AM)Tim Wessman Wrote:
(10-25-2019 08:47 AM)rombva Wrote:  Thanks!
Replacing the ∫(...) by the int(...) removed the garbage names genartion in my all cas programms.
