(HP-67/97) U.S. Standard Atmosphere
10-24-2019, 02:45 AM
An extract from the U.S. Standard Atmosphere on the HP67/HP97, US Dept of Commerce, NOAA (NWS), National Meteorological Center, JUN 1977 (5 pgs)
"General
When one of pressure, height, temperature, or potential temnperature is input, the program outputs the other three. The program is on a magnetic card, one side containing the program itself, the other side the constants.
Input and output
To operate the program, first read in both sides of the magnetic card. Then key in the input parameter and press the key shown in the table. Outputs will be stored in the registers …
On the HP97 output will also be printed in the order: pressure, height, temperature, potential temperature. On the HP67 output will be flashed on the display in the same order.
Program listing"
001 - 112 (page 5)
BEST!
SlideRule
