hp-prime ß firmware test (October 24, 2019)
10-25-2019, 03:14 AM (This post was last modified: 10-25-2019 05:09 AM by compsystems.)
Hello
Even without learning to write in English =(, google translator v
In the emulator
Sometimes it shows in the history view a decimal point on the integer value.
In exact mode [Shift]+[CAS] Exact:✔
PHP Code:
Width := 20;
Height := 9
Width Height;
17/3
[enter
should always shows the following.
20
45
900
17/3
and not
20.
45.
900.
5.66666666667
Is the same thing happening in your emulator or device?
10-25-2019, 04:33 AM
RE: hp-prime ß firmware test (October 24, 2019)
Look in your CAS Settings and make sure Exact is turned on.
