How you can change keyboard colors in Prime Android Emu
11-16-2019, 04:32 PM (This post was last modified: 11-16-2019 10:08 PM by FrankP.)
for those of you, having also problems with the orange letter colors on the Prime Android App:
By accident I came across the free Android 'APK Editor' App. After installation:
  1. select 'APK from App' or 'File' and choose your HP Prime APK.
  2. Select 'Simple Edit',
  3. change in group 'Files' to 'res' subdir 'drawable-nodpi-v4'.
  4. Select the edit button near to eg. 'portrait_skin.png'.
  5. Select the file you want to replace the original file with. Same dimension and size required.
  6. Press 'Save'.
After several minutes, the modified APK is saved to your Phone and is waiting to replace the standard HP Prime installation.
For editing the PNG on the Android, I used the also free 'Photo Editor 5.1'. My PNG files
.zip  portrait_bg_and_skin.zip (Size: 943.21 KB / Downloads: 7) for the following result
    with Emu 2.1.14294 (2019 10 25) on Android 7.1.
11-16-2019, 06:07 PM
RE: changing keyboard colors in Prime Android Emu
if you could find a solution for physical HP, I'd be grateful for it for life.
11-17-2019, 07:37 PM
RE: How you can change keyboard colors in Prime Android Emu
(11-16-2019 06:07 PM)nbenm Wrote:  if you could find a solution for physical HP, I'd be grateful for it for life.
Careful painting then clear layer on top
11-17-2019, 09:41 PM
Or perhaps labels.
https://hpmuseum.org/forum/thread-211-po...l#pid13996
11-17-2019, 09:57 PM
(11-17-2019 09:41 PM)Steve Simpkin Wrote:
(11-17-2019 07:37 PM)CyberAngel Wrote:  Careful painting then clear layer on top
Or perhaps labels.
Both Prime color schemes
You could do the painting yourself - if you just could...
VPN
11-18-2019, 01:25 AM
Modify the .STL file before submitting it to your Star Trek replicator?
11-18-2019, 06:04 AM
Cyrille
You could use a cnc machine to do 3D engraving on the keys directly!
Then use some other plastic to do the inlays and you are good to go!
https://www.tomtop.com/fr/p-e8250-500.ht...n0QAvD_BwE
