HP-35s Order of arguments with RPN
11-25-2019, 12:44 PM
I'm reading the manual for the HP-35s and I'm confused with RPN input mode on page 1-20. The top display line of the calculator shows the y register and the lower line shows the x register (Page 2-2). Now page 1-20 shows how to enter 6C4 in both modes. In RPN the 6 stands in Y register and 4 in X when nCr is pressed which would translate to nCr(4,6) if the function notation is f(x,y). Also if this is right the xth root of y exception mentioned on the page would be none. But in ALG mode nCr(6,4) is entered, which would translate to f(y,x). What am I missing in my understanding? |
11-25-2019, 09:32 PM
RE: HP-35s Order of arguments with RPN
They seem to have arranged things so that you enter n (the larger number) first, then r, regardless of whether you're using RPN or ALG mode.
On older HP models, e.g. HP-15C, the key is marked Cy,x, where y is n. Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot Casio, Rockwell 18R |
