a modulo b [solved]
12-17-2019, 06:17 PM (This post was last modified: 12-17-2019 06:44 PM by Aistoipok.)
a modulo b [solved]
I'd want to obtain a mod b by typing a% b but it doesn't work (syntax error)
[edit] I have to typing a %% b
12-18-2019, 06:20 AM
RE: a modulo b [solved]
hello,
The modulo command is MOD and is used as an operator, not a function, hence the syntax is:
9 MOD 4 (returns 1)...
% is for percentages and is a function as in %(5,40) = 2 (40 percent of 5 is 2)...
Cyrille
12-18-2019, 08:15 AM (This post was last modified: 12-18-2019 08:17 AM by ijabbott.)
In CAS mode, n %% m enters a number as a member of an arithmetical ring. Strangely, it gets pretty-printed as %%(n,m) on the left of the display in textbook display mode, but results are always displayed as n' %% m on the right of the display (where n' is the member of the ring congruent to n). Trying to enter the number as %%(n,m) produces a syntax error.
— Ian Abbott
