(SR-52) In defense of linear quadrature rules
12-22-2019, 02:14 PM
An extract from In Defense of Linear Quadrature Rules, William Squire (Aerospace Engineering Dept., West Virginia University), Comp. & Maths with Apple, Vol. 7, pp. 147.-149, Pergamon Press Ltd., 1981
Abstract--lt is shown that appropiate linear quadrature rules can handle integrands with singularities at or near the end points more effectively than the nonlinear methods proposed by Werner and Wuytack. A special 10 point Gauss rule gives good results. A method with exponential convergence gives high accuracy with a moderate number of nodes. Both procedures were implemented on a programmable hand calculator. INTRODUCTION The purpose of this note is to demonstrate that: (1) a special 10 point Gauss rule for integrands with singularities at or near the endpoints proposed by Harris and Evans [2] will give results comparing favourably to any other procedure using a comparable number of nodes. (2) A quadrature rule, which Stenger [3] has shown to have exponential convergence, gives very accurate results for such integrands with a moderate number of function evaluations. Both these procedures were implemented on an SR 52 programmable hand calculator. … The SR-52 implementation is given in Appendix A … … The method was implemented on an SR-52 as described in Appendix B … … APPENDIX A Harris-Evans 10 point rule … … APPENDIX B SR-52 program for Stenger quadrature (equation 1) … BEST! SlideRule |
12-22-2019, 06:23 PM
(This post was last modified: 01-16-2020 02:13 PM by Albert Chan.)
RE: (SR-52) In defense of linear quadrature rules
Thank you, SlideRule.
I tried this modified point / weight quadrature on \(\int _0^6 e^{x^3}\; dx ≈ 5.963938092 × 10^{91}\) gp/gw from Gaussian Quadrature Weights and Abscissae (n=10, rounded to 10 digits) mp/mw is modified points/weights from In Defense of Linear Quadrature Rules, table 1 lua> gp = {0.1488743390, 0.4333953941, 0.6794095683, 0.8650633667, 0.9739065285} lua> gw = {0.2955242247, 0.2692667193, 0.2190863625, 0.1494513492, 0.06667134431} lua> mp = {0.2295037173, 0.6364758401, 0.9015072053, 0.9928383122, 0.9999843443} lua> mw = {0.4501100825, 0.3483026852, 0.1744679776, 0.02696299772, 0.0001562579734} lua> function integ(f,a,b,p,w) -- 10 points quadrature : local t, m, c = 0, (b-a)/2, (b+a)/2 : for i=1,5 do t = t + (f(-m*p[i]+c) + f(m*p[i]+c)) * w[i] end : return m * t : end lua> function f(x) return math.exp(x^3) end lua> integ(f, 0, 6, gp, gw) → 3.052910317e+089 lua> integ(f, 0, 6, mp, mw) → 5.444304730e+091 Modified point/wieght looks much closer. However, if we integrate only the dominant part, plain guassian points is better. lua> integ(f, 5.50, 6, gp, gw) → 5.942395811e+091 lua> integ(f, 5.50, 6, mp, mw) → 5.577982336e+091 lua> integ(f, 5.75, 6, gp, gw) → 5.963893713e+091 lua> integ(f, 5.75, 6, mp, mw) → 5.907966288e+091 |
