May I assume assume bug?
12-24-2019, 06:41 PM
(This post was last modified: 12-25-2019 02:24 AM by CyberAngel.)
Why 4?
VPN __________________________________ CAS....................Function __________________________________ purge(m0)............................................4 m0....................................................m0 assume({m0},DOM_INT)............DOM_INT 'm0=2*k0'................................m0=2*k0 m0...........................................DOM_INT k0............................................DOM_INT m0=2*k0.............................................4 __________________________________ |
12-24-2019, 10:50 PM
RE: May I assume assume bug?
Image links must be to actual images, not merely to pages that display an image. An easy way to know whether a link will work as an image is if the link itself ends with an image file extension, such as .jpg or .png and so on. The following link works because it ends in .jpg
<0|ΙΈ|0> -Joe- |
