Print TIME and DATE
12-29-2019, 07:27 PM
Print TIME and DATE
Could you help me?
I have a HP41CX When I'm using some HP-IL printer, like HP2225C, I'd like to print the TIME and DATE in first line. Thanks for help me |
12-30-2019, 06:05 PM
RE: Print TIME and DATE
(12-29-2019 07:27 PM)Dinamarco Wrote: Could you help me? This is probably clunky, but seems to work: CLA TIME ATIME |-" " DATE ADATE PRA Dave - My mind is going - I can feel it. |
12-31-2019, 02:41 PM
Nice....
I tried but... CLA TIME ATIME |-" " (how do I type it in HP41cx ?) DATE ADATE PRA Could you answer me? |
12-31-2019, 03:03 PM
(This post was last modified: 12-31-2019 03:06 PM by twoweims.)
It is the "APPEND" Symbol
ALPHA - SHIFT - K Followed by a Space. |
12-31-2019, 03:08 PM
ok. Thanks a lot!
Another simple question: Is possible to print an simple text after a question, for example: NAME? PROMPT DINAMARCO |
12-31-2019, 05:52 PM
(This post was last modified: 12-31-2019 05:57 PM by Jeff O..)
(12-31-2019 02:41 PM)Dinamarco Wrote: ... Sorry I did not see your question sooner, I should have realized that the APPEND function might not be obvious. Thanks to twoweims for answering. I also realized my code could use some more work. The ATIME and ADATE functions observe or obey the current display mode to some exent, so some FIX commands would be needed to insure a pleasing output. Something like the below gives good results: CLA FIX 02 TIME ATIME |-" " DATE FIX 04 ADATE PRA Above provides hours and minutes for the time, for example, if I execute it at this very moment, I get: 12:40 PM 12/31/19 If hours minutes and seconds are preferred, just put a FIX 04 at the beginning and get: 12:40:15 PM 12/31/19 If DMY is preferred: 12:40 PM 31.12.19 If 24 hour time is prefrerred: 12:40 31.12.19 If you want the whole year, replace the FIX 04 with a FIX 06: 12:40 PM 12/31/2019 Dave - My mind is going - I can feel it. |
12-31-2019, 07:42 PM
Thanks DAVE...
I wrote it in my small program. Best Regards... |
12-31-2019, 07:59 PM
(This post was last modified: 12-31-2019 08:04 PM by Sylvain Cote.)
(12-31-2019 03:08 PM)Dinamarco Wrote: Another simple question: Is possible to print an simple text after a question, for example: On the LCD no (well, yes but not really), on the printer yes. Code: LBL "TEST" // test program Printer output: Code: NAME ? SYLVAIN |
12-31-2019, 09:50 PM
Solved!!!
Thanks a lot for everyone who help me! Happy new year!!! |
01-01-2020, 03:25 PM
Happy new year every one!
Late and probably a bit outside the scope but here's a few line of code I use to display the date in french. Code:
Once the pointer in the program, 03 LBL D is there to display any given date in X. Line 06 is Append Space. Lines 07 & 11 are synthetic instructions to keep the previous status (flags) of the 41, they can be omitted. Also this nice to see that there's still HP2225C printers out there. Mine is out of order cause the cartridge wasn't removed by the previous owner. |
01-01-2020, 04:54 PM
(01-01-2020 03:25 PM)dayd Wrote: Late and probably a bit outside the scope but here's a few line of code I use to display the date in french. Alternative implementation using X<>F instead of XEQ IND X. DOW converted into flags with X<>F Code: 000 : DIM / SUN Program listing: (based on yours) Code: LBL "JOUR" |
01-01-2020, 05:49 PM
Nice...
I'm able to translate to Portuguese Regards. Nice 2020! |
01-01-2020, 08:31 PM
HP 2225 head
I'm able to send you another "head" from HP2225. If you want it, let me know. you gonna pay only the Shipping. Best regards. Thanks again for your help |
01-01-2020, 08:56 PM
Indeed, I'm interested...
[PM sent] André |
01-01-2020, 09:04 PM
RE: Print TIME and DATE | |||
01-01-2020, 09:26 PM
Quote:Do you speak Portuguese or English?Both (in a limited way), and french of course. Quote:send me a private message with your address.Very nice! Would love to see it working. Thanks a lot [re-PM] Quote:Alternative implementation using X<>F instead of XEQ IND X. Always cool to see others way of writing code |
