Evaluate an expression for given points
01-12-2020, 09:28 AM
Hi there
I would like to evaluate the following expression for even and odd n‘s
One solution could be to type in n=1 then, n=2 and so on but this is time consuming. Is there a way to directly define the numbers where to evaluate the expression?
I have tried with n=[0 1] then the calculator crashed...
Thank you.
Blevita
Attached File(s) Thumbnail(s)
01-12-2020, 10:22 AM (This post was last modified: 01-12-2020 10:23 AM by Tyann.)
RE: Evaluate an expression for given points
(01-12-2020 09:28 AM)blevita Wrote:  Hi there
Thank you.
Blevita
Bonjour
Utilisez une liste {1,2,...} à la place de n.
Hello
Use a list {1,2,...} instead of n.
Sorry for my english
01-12-2020, 11:44 AM
Merci
Ca cest tres bien.
Worked perfectly
01-12-2020, 08:25 PM
(01-12-2020 09:28 AM)blevita Wrote:  I would like to evaluate [an] expression for even and odd n‘s...
Is it practical to calculate f(x)=2/(n*pi) and multiply f(x) by (n MOD 2)?
This should return f(x) for odd n and 0 for even n.
it's possible to do the same thing if you don't have the MOD function by cleverly using (-1)^n.
17bii | 32s | 32sii | 41c | 41cv | 41cx | 42s | 48g | 48g+ | 48gx | 50g | 30b
01-13-2020, 02:28 AM
irem
