A single memory module for a usb cable / using in a 41CL
01-23-2020, 06:55 PM
I am currently soldering a usb cable to a single memory module for a colleague's 41CL. Can I leave the memory module as it is or do I have to cut conductor tracks?
Thanks for hints Hans-Peter |
01-23-2020, 09:05 PM
RE: A single memory module for a usb cable / using in a 41CL
The problem is solved. I just cut out the Memory :-(
I hope the HP gods may forgive me :-) |
01-24-2020, 06:49 AM
RE: A single memory module for a usb cable / using in a 41CL | |||
01-26-2020, 09:44 AM
Can't speak on behalf of the gods but assuming you're building a USB power cable, you've taken the right decision. :-) Cheers! "Do not suppose, check it twice." |
01-26-2020, 05:43 PM
As long as you intend to use the cable for the 41CL only, you could probably have left the memory in place. The 41CL will not access the bus to read RAM as it has it all internally (as I understand it).
User(s) browsing this thread:
