20021 Install Question
01-24-2020, 02:39 AM
I’m a dinosaur...cannot figure out how to get the Connectivity Kit to find and install the new firmware. I have the new firmware in: Libraries Documents HP Connectivity Kit Firmware.
How do I get the Connectivity Kit to find and install the 16,828 KB file?
01-24-2020, 03:31 AM
RE: 20021 Install Question
(01-24-2020 02:39 AM)lrdheat Wrote:  I’m a dinosaur...cannot figure out how to get the Connectivity Kit to find and install the new firmware. I have the new firmware in: Libraries Documents HP Connectivity Kit Firmware.
Connectivity settings will give you the path to the right directory.
Inside you'll find Firmware.
Then either G1 or G2.
I ALWAYS save the old files (in OLD_G1) first
only then I overwrite = copy over the old files.
VP
01-24-2020, 03:35 AM
Assuming you have a Prime G2:
1. Close the ConnKit (CK) if it's running
2. Extract the contents of the new f/w .zip file from hpcalc.org into this folder: (delete any old files in there first)
C:\Users\YOUR_NAME\Documents\HP Connectivity Kit\Firmware\PrimeG2
3. Connect the Prime to the USB cable
4. Start the CK
5.a. It should automatically prompt you to update your device - proceed
5.b If it doesn't prompt you, right-click on your connected Prime icon and select UPDATE from the menu
The new f/w is downloaded and automatically installs
6. Enjoy your updated Prime
01-24-2020, 07:55 PM
Success! Our assistant engineer at the TV station (I am the chief meteorologist) was able to negotiate through the administrative privileges stuff that was standing in my way!
