Prime still varying in speed (last firmware)
01-25-2020, 03:01 PM
(This post was last modified: 01-25-2020 03:02 PM by Oulan.)
With the last firmware (and a factory reset) with the following prog
Code: #pragma mode( separator(.,;) integer(h32) ) The speed still can be as slow as 293 it/sec and faster up to 11297 it/sec This is quite strange ... |
01-25-2020, 05:38 PM
RE: Prime still varying in speed (last firmware)
Bonjour
j'ai remarqué également des ralentissement à l'exécution de programmes sur ma G2 bien que je sois encore en version 2.1.14284 béta. J'ai même un programme dans lequel des petites balles se balladent à l'écran qui semble être plus rapide sur la G1 ? Je vais faire les mise à jour demain et verrai si le problème persiste. Hello I also noticed slower program execution on my G2. although I'm still in version 2.1.14284 beta. I even have a program in which little balls are wandering around on the screen that seems to be faster on the G1? I'll do the updates tomorrow and see if the problem persists. Sorry for my english |
01-27-2020, 05:50 AM
(This post was last modified: 01-27-2020 05:52 AM by Tyann.)
Bonjour
Je viens de voir un post :ici dans lequel un utilisateur remarque lui aussi qu'un même programme va plus vite sur G1 que sur G2. Hello I just saw a post: here in which a user also notices that the same program goes faster on G1. than on G2. Sorry for my english |
01-27-2020, 08:29 PM
(01-25-2020 03:01 PM)Oulan Wrote: With the last firmware (and a factory reset) with the following prog Same results. It seems to run between 288 and 11390 in my G2, randomly as far as I can tell. |
