Review: Calculated Industries Tradesman Calc
02-01-2020, 09:05 PM
Snippet:
Features * Units and unit conversions * Right Triangle Calculations * Ratio Calculations * Trigonometry * Geometry Calculations Other mathematical functions: reciprocal, powers, roots, degrees/degrees-minutes-seconds, parenthesis The calculator operates in one of two modes: Order and Chain Order uses order of operations while chain completes calculations as keys are pressed (like a four-function calculator). Order of operations is the default setting. Fraction settings allow you to set the largest denominator, up to 64. The keyboard is a pleasure to use. Aside it being blue (blue is my favorite color), the keys have a pleasant touch and register perfectly. The display is clear with prompts. The Tradesman Calc comes with a hard case cover. On the back of the calculator, there is a slot for a battery and another for user guide. Link: https://edspi31415.blogspot.com/2020/02/...esman.html |
