hp41cx named variables in extended memory
02-03-2020, 10:43 PM
Was there a utility routine in PPC or other that let you create named variables in extended memory? I thought there was?
I know the performance would suffer but it might suite my application. I am picturing something that let you store a name in Alpha and it would provide CRUD functions to manage a value stored under that name in EM. Thanks! Todd |
02-04-2020, 05:28 AM
(This post was last modified: 02-04-2020 05:28 AM by dayd.)
RE: hp41cx named variables in extended memory
Hi Todd,
I use this sub that I wrote to retrieve currency values (devise is French for currency) from a text file, no other module than XF or CX is needed. At start the currency code name is in alpha. And the value ends in x of course. Code: LBL "DEVISE" The "DBD" text file come regularly from a script on my phone (I don't have the internet in my CX, yet...) and looks like this; Code: UPD 03,022020 I have a similar system for GPS coordinates with 2 values per record and the ANUMDEL function from the XIO module come handy in that case. I think that the Paname rom have interesting related functions, too. André |
02-27-2020, 02:54 AM
(This post was last modified: 02-29-2020 04:39 PM by Artur - Brasil.)
I'm writing two programs for 41C with X-Functions and X-Memory. One creates a data file in X-Memory for replacing registers from 00 to 10 (it can replace any register, actually, if you get memory to hold the programm (or a NovRAM - HEPAX module). So, operations like RCL 05 will be written as XEQ "R5"; STO 05 as XEQ "S5" One subroutine creates the file: ALPHA: name of file; X: number of registers - XEQ "XREG" One subroutine for each "Rn" and one for each "Sn". It's quite a byte consumming, but works. You can get private data registers for every program. The routine CU, in synthetic programming books is not very usefull - only for called programs: after you called it, the n registers (in main memory) will desappear to the called program. My got another way, but eats bytes... It's already finished. The second program is for creating a file in X-Memory for named variables (name up to six charaters) , for numeric or alpha contents. I'm writting it. One subroutine creates the file: ALPHA: name of file XEQ "XVAR". Two subroutines for recovering values: in ALPHA, put the name of variable. So, if numeric, XEQ "XRCL": the content will be recovered to X; if alpha, XARCL will recover content to ALPHA. For storing data, ALPHA: name:value XEQ "XSTO", either for alpha or numeric variable. What do you think about this idea? Best wishes from Brazil Artur ARTUR MARIO JUNIOR BRAZIL |
02-27-2020, 01:15 PM
(02-27-2020 02:54 AM)Artur - Brasil Wrote: What do you think about this idea? Greetings Artur, very interesting. I have an unusual pattern when I program the '41cx. I associate a six character mnemonic with each important register variable and i create a table in extended memory that links a strict type with the name and register number. I have a simple routine to display them. I also use a six character label for each function (but I always wind up scavaging those back to simple numeric labels to recover registers as the program grows). Its the only way I can write "literate" code in the 41 that lets me set the project down and stand a chance when I come back to it. Your function(s) might provide a better way to actually drive the register values to EM. Especially since, once I had the program debugged, I could move them "back" into registers to recover performance. please share as you develop your utilities. Regards Todd |
02-27-2020, 03:03 PM
Yesterday at night, I realized another way to make the STO function for numeric x-registers from 10 to 19.
It is using flag 10. If you want to store in x-register 10 or above, just set flag before calling S0, S1, S2 ... S9 (I'll add 10, giving S10, S11 .. S19). This solution will save many bytes for routines from S10 ... S19. I did not analyze the impact on RCL function yet. Let's see if it will also be possible to use flag 10 too for RCL. I believe the majority of programs use less than 10 registers - so, this solution would work well. Putting the SF 10 instruction before restoring from 10 to 19 will be tedious. It's something to analyze... I'll provide both solutions and wait for community improvements. HP-41 is really a great computer system! Best wishes! Artur ARTUR MARIO JUNIOR BRAZIL |
02-27-2020, 03:50 PM
Quote:Its the only way I can write "literate" code in the 41 that lets me set the project down and stand a chance when I come back to it.If your goal is more readable code then I know there's a 41C compiler that runs on a PC and lets you use names instead of register numbers (numbered labels too?) So you can do things like: Code: define COUNTER 01 |
02-27-2020, 04:44 PM
Quote: I have an unusual pattern when I program the '41cx. I associate a six character mnemonic with each important register variable and i create a table in extended memory that links a strict type with the name and register number. If I understood well, you create a reference table, like a help for remembering what REG 10, by example, means in your programm. RAM X-MEMORY FILE REG 10 ---> 10 Prices average (example) It's a great idea too! But my work is in another way! Store values in X-memory like you do in RAM. STO 05 ---> S5 RCL 05 ---> R5 Best wishes! Artur ARTUR MARIO JUNIOR BRAZIL |
02-27-2020, 08:21 PM
(This post was last modified: 02-28-2020 02:41 PM by Artur - Brasil.)
(02-27-2020 03:50 PM)David Hayden Wrote:Great, David, but as you told, this compiler runs on a PC, so, it's not portable as my 41CX. I'm making one for 41 with X-funtions and X-Memory on 41CX. Even if it does not add too much in importance, it is beeing a great adventure make it!Quote:Its the only way I can write "literate" code in the 41 that lets me set the project down and stand a chance when I come back to it.If your goal is more readable code then I know there's a 41C compiler that runs on a PC and lets you use names instead of register numbers (numbered labels too?) So you can do things like: Artur ARTUR MARIO JUNIOR BRAZIL |
02-28-2020, 02:27 PM
(This post was last modified: 02-28-2020 02:59 PM by Artur - Brasil.)
Hi, guys!
Here is the code for creating numeric registers in X-Memory, version 1. No use of flag 10. Version 1 - stores from 00 to nnnnnn, limited only to program memory and X-Memory available. Main program: creates the X-file to hold numeric registers, given ALPHA: file name X:number of registers (ex: 15 - will be available 00 to 14) LBL "XREG" SF 25 CRFLD FC?C 25 RSZFL if file already exists, resize it, in case you have changed to a bigger os smaller file CLX SEEKPTA RTN LBL "R0" global labels for Restoring (RCL) - just call them in your program or from keyboard 0 GTO 00 LBL "R1" 1 GTO 00 LBL "R2" 2 GTO 00 ... repeat LBL "Rnnnn" as many times your biggest neccessity of storage registers ... but be aware we are calling a local label, so, distance from fist GTO 00 must be ... less than 112 Byte ... my experience showed that you can create up to R10 and this limitation will be ... preserved. After routine LbL 00, you can resume LBL "R11" up to "R19" and distance ... will be less than 112Byte LBL "R2" 10 the last routine just befor LBL 00 doesn't need the GTO 00 instruction! LBL 00 local subroutine to make the restoring work - preserves Y,Z,T stack registers, as STO SEEKPT CLX GETX RTN ... as told before, you can continue with "R11" up to "R19" here, if desired. Let's put two ex. LBL "R11" 11 GTO 00 ... LBL "R19" 19 GTO 00 well, if you need more registers, for each group of nine (R20-R28, R29-37, ...) you must replicate the LBL 00 subroutine as LBL 02, LBL 03, for example, and change the GTO 00 to GTO 02, GTO 03 too. The distance limitation will be preserved. LBL "S0" here we star the restoring global labels. As "Snn", just call them from programs or k. X<> L Storing is more complicated and consumes more bytes, but preserves stack, as STO CLX 0 GTO 01 LBL "S1" X<> L CLX 1 GTO 01 ... again, insert as many "Snn" routines as you have created "Rnn". The distance limitation for GTO 01 exists too. You can put up to "S9" before the subroutine LBL 01 LBL "S9" X<> L CLX 9 the last routine just before LBL 01 doesn't need the GTO 01 instruction! LBL 01 here the routine which saves the X contents. SEEKPT X<> L SAVEX RTN ... as told before, you can continue with "S10" up to "S17" here, if desired. Let's put one ex. ... LBL "S17" X<> L CLX 17 GTO 01 well, if you need more, for each group of seven (S18..S24, S25..31...) you must replicate the LBL 01 subroutine as LBL 05, LBL 06 and change GTO 01 to GTO 05, GTO 06... The distance limitation will be preserved. END ARTUR MARIO JUNIOR BRAZIL |
02-28-2020, 02:37 PM
(This post was last modified: 02-28-2020 05:35 PM by Artur - Brasil.)
As seen above, the code gets bigger as number of registers to store/restore increases.
For 19 registers, the program gets 180 lines, 499 bytes. Another infortune was routines for storing beeing bigger than for recalling, leading to the number of recalling storing around LBL 01 being different of recalling. So, I put my head to work: using FLAG 10 could prevent creating routines for working with registers from 10 to 19. But... you will need to set flag 10 before storing or restoring from 10 .. 19. Example: SF 10 XEQ "R4" will restore the value of register 14 instead of 4. This solution will save a lot of bytes, but is limited to register 19 (9 + 10) and requires user remembers of including SF 10 instruction before XEQ "Rnn" Best wishes Artur ARTUR MARIO JUNIOR BRAZIL |
02-28-2020, 07:52 PM
(This post was last modified: 02-29-2020 02:36 AM by Artur - Brasil.)
Here the full version 2.1 - using FLAG 10 for sto/rcl 10-19 (remember, size of file must be 1+ the higher register number you're going to use - up to 19 in this version).
323 bytes against 499 of version 1 !!! 1 LBL "XREG2" creates the file for X-Regs given ALPHA: file_name X: number of regs (you will have 0...n-1) 2 SF 25 3 CRFLD 4 FC?C 25 5 RESZFL if file already exists, just resize it. 6 CLX 7 SEEKPTA 8 RTN 9 LBL "R0" to recover regs from 00 to 09, just call XEQ "R0" .. XEQ "R9". 10 0 For registers from 10..19: SF 10 XEQ "R0" .. XEQ "R9" 11 GTO 00 each time you call Sn or Rn routines, FLAG 10 is cleared automatically. 12 LBL "R1" 13 1 14 GTO 00 15 LBL "R2" 16 2 17 GTO 00 18 LBL "R3" 19 3 20 GTO 00 21 LBL "R4" 22 4 23 GTO 00 24 LBL "R5" 25 5 26 GTO 00 27 LBL "R6" 28 6 29 GTO 00 30 LBL "R7" 31 7 32 GTO 00 33 LBL "R8" 34 8 35 GTO 00 36 LBL "R9" 37 9 38 LBL 00 the local label that process STO work 39 FS?C 10 40 XEQ 02 41 SEEKPT 42 CLX 43 GETX 44 RTN 45 LBL 02 auxiliary routine for regs 10 ... 19 46 RUP 47 STO L 48 RDN 49 10 50 STO+ Y 51 X<> L 52 RDN 53 RTN 54 LBL "S0" to store regs from 00 to 09, just call XEQ "S0" .. XEQ "S9". 55 X<> L For registers from 10..19: SF 10 XEQ "S0" .. XEQ "S9" 56 RDN 57 FC? 10 58 0 59 FS?C 10 60 10 61 GTO 01 62 LBL "S1" 63 X<> L 64 RDN 65 FC? 10 66 1 67 FS?C 10 68 11 69 GTO 01 70 LBL "S2" 71 X<> L 72 RDN 73 FC? 10 74 2 75 FS?C 10 76 12 77 GTO 01 78 LBL "S3" 79 X<> L 80 RDN 81 FC? 10 82 3 83 FS?C 10 84 13 85 GTO 01 86 LBL "S4" 87 X<> L 88 RDN 89 FC? 10 90 4 91 FS?C 10 92 14 93 GTO 01 94 LBL "S5" 95 X<> L 96 RDN 98 FC? 10 99 5 100 FS?C 10 101 15 102 LBL 01 103 SEEKPT 104 X<> L 105 SAVEX 106 RTN 107 LBL "S6" 108 X<> L 109 RDN 110 FC? 10 111 6 112 FS?C 10 113 16 114 GTO 01 115 LBL "S7" 116 X<> L 117 RDN 118 FC? 10 119 7 120 FS?C 10 121 17 122 GTO 01 123 LBL "S8" 124 X<> L 125 RDN 126 FC? 10 127 8 128 FS?C 10 129 18 130 GTO 01 131 LBL "S9" 132 X<> L 133 RDN 134 FC? 10 135 9 136 FS?C 10 137 19 138 GTO 01 139 END ARTUR MARIO JUNIOR BRAZIL |
02-29-2020, 12:17 PM
[quote='Artur - Brasil' pid='128543' dateline='1582919576']
Here the full version 3.0 - using FLAG 10 for sto/rcl 10-19, BUT, with just 263 bytes, against 323 bytes of version 2.1 and 499 of version 1.0! How it was possible? I modified the registers mapping from what user sees and how to store them. Version 2.1: WANTED X-REG 00 ----> 00 01 ----> 01 ... 19 (FLAG 10) --> 19 Version 3.0: 00 --> 00 01 --> 02 02 --> 04 03 --> 06 ... 09 --> 18 10 --> 01 11 --> 03 12 --> 05 ... 18 --> 17 19 --> 19 And instead of add 10, I removed 1, using DSE, which does not disturb stack! Great! 1 LBL "XREG2" 2 SF 25 3 CRFLD 4 FC?C 25 5 RESZFL 6 CLX 7 SEEKPTA 8 RTN 9 LBL "R0" 10 1 11 GTO 00 12 LBL "R1" 13 3 14 GTO 00 15 LBL "R2" 16 5 17 GTO 00 18 LBL "R3" 19 7 20 GTO 00 21 LBL "R4" 22 9 23 GTO 00 24 LBL "R5" 25 11 26 GTO 00 27 LBL "R6" 28 13 29 GTO 00 30 LBL "R7" 31 15 32 GTO 00 33 LBL "R8" 34 17 35 GTO 00 36 LBL "R9" 37 19 38 LBL 00 39 FC?C 10 40 DSE X 41 SEEKPT 42 CLX 43 GETX 44 RTN 45 LBL "S0" 46 X<> L 47 RDN 48 1 49 GTO 01 50 LBL "S1" 51 X<> L 52 RDN 53 3 54 GTO 01 55 LBL "S2" 56 X<> L 57 RDN 58 5 59 GTO 01 60 LBL "S3" 61 X<> L 62 RDN 63 7 64 GTO 01 65 LBL "S4" 66 X<> L 67 RDN 68 9 69 GTO 01 70 LBL "S5" 71 X<> L 72 RDN 73 11 74 LBL 01 75 FC?C 10 76 DSE X 77 SEEKPT 78 X<> L 79 SAVEX 80 RTN 81 LBL "S6" 82 X<> L 83 RDN 84 13 85 GTO 01 86 LBL "S7" 87 X<> L 88 RDN 89 15 90 GTO 01 91 LBL "S8" 92 X<> L 93 RDN 94 17 95 GTO 01 96 LBL "S9" 97 X<> L 98 RDN 99 19 100 GTO 01 101 END One further improvement: replace all: X<> L 2 byte RDN 1 byte = 3byte*9 = 27byte For: XEQ 03 2byte * 9 = 18 ... LBL 03 2 X<> L 2 RDN 1 RTN 1 = 6byte + 18 = 24byte, only 3 bytes of gain. But one more XEQ and subroutine level. ARTUR MARIO JUNIOR BRAZIL |
03-01-2020, 01:26 AM
(This post was last modified: 03-01-2020 10:26 AM by Artur - Brasil.)
Making a simple arithmetic:
20 regs in HP-41 memory = 7bytes * 20 = 140 bytes My routines use, for the same 20 regs : 499 bytes or 263 bytes (and more X-Memory to hold the registers). If you see just the bytes, no way to win this war. But the main idea is to have private numbered registers for those programs that serve as basis for others. Both routines make the x-file the current one only at initialization. So, if your programs make use of others X-files, you will need to make the X-Reg file the current one again. Best wishes! Artur - Brasil ARTUR MARIO JUNIOR BRAZIL |
03-17-2020, 09:32 PM
(This post was last modified: 03-18-2020 02:48 PM by Artur - Brasil.)
Revison A (mars, 18th)
As promised, although nobody indeed made even any comment about it, here the routine to create named variables in X-memory, complementing the X-Memory numbered registers routine published before. The vars must have a name up to 5 chars. Example: WIDTH. Please, do not use : in variable name. All variables will be saved in a X-files which names you give. Each X-File has no limit for number of variables, only limited to memory available. The use is very simple: put the name of file (to be created or already existing) in ALPHA, by example: BOX. If file does not exist yet, it will be created; if already exists, the program just open it. IMPORTANT: both routines (STA and RCA) make the x-file the current one only at initialization (XVARN). So, if your programs make use of others X-files, you will need to make the X-Reg file the current one again. Call XVARN (X-Variables Named) routine: ALPHA BOX ALPHA XEQ ALPHA XVARN ALPHA Now, you must have one text X-File named BOX. (See cathalog 4 in CX) For creating and saving the variable LEN with value 10, just type: ALPHA LEN ALPHA 10 XEQ ALPHA STA ALPHA. (Store Alpha named variable) Create as many variables your X-Memory modules can hold. Not allowed two variables in the same file with same name. For recovering the contents of any named variable, put its name in ALPHA register and call RCA routine. ALPHA LEN ALPHA XEQ ALPHA RCA ALPHA --> X: 10 I saved variables in X-file as: namen.nnnnnnnnEsnn (s - signal) Numeric values are stored in American and Scientiic format, up to 9 digits of precision. This may lead to something like: LEN:1,200000000E1 which is a waste of precious bytes on 00000000 sequence. So, I created a routine to clean these unneccessary zeroes and compress the file to minimal registers needed. Eventually, call CLNVAR (clear nominal var file), with the current x-file as the one you want to clean or insert a call to it in the XVARN routine. So, it will run when you start the process (remove the VIEW commands in routine CLNVAR. Here is the full code (REV A) 1 LBL "XVARN" 2 X<> L 3 RDN 4 1 5 SF 25 6 CRFLAS 7 CF 25 8 X<> L 9 RTN 10 LBL "STA" 11 X<> L 12 RDN 13 58 14 XTOA 15 RDN 16 POSFL 17 X<0? 18 GTO 02 19 DELREC 20 X<> L 21 LBL 03 22 RCLFLAG 23 RDN 24 SF 28 25 SCI 9 26 ARCL X 27 APPREC 28 RUP 29 STOFLAG 30 CLX 31 SEEKPT 32 RDN 33 RTN 34 LBL 02 35 X<> L 36 ASTO L 37 CLA 38 FLSIZE 39 ARCL L 40 x<> L 41 RDN 42 4 43 ST+ L 44 X<> L 45 RESZFL 46 RDN 47 GTO 03 48 LBL "RCA" 49 STO L 50 CLX 51 SEEKPT 52 RDN 53 58 54 XTOA 55 RDN 56 POSFL 57 X<0? 58 GTO 01 59 GETREC 60 CLX 61 SEEKPT 62 RDN 63 RCLFLAG 64 X<> L 65 SF 28 66 SCI 9 67 ANUM 68 X<> L 69 STOFLAG 70 X<> L 71 RTN 72 LBL 01 73 X<> L 74 "^NOT FOUND" 75 AVIEW 76 BEEP 77 RTN 78 LBL "CLNVAR" compress named vars x-file to minimal neccessary of bytes 79 CLA 80 X<> L 81 RDN 82 FLSIZE 83 VIEW X 84 LBL 06 85 CLX 86 SEEKPT 87 "0E" 88 RDN 89 POSFL 90 X<0? 91 GTO 07 92 VIEW X 93 ST/ X 94 DELCHR 95 GTO 06 96 LBL 07 97 RDN 98 CLA 99 FLSIZE 100 SF 25 101 LBL 08 102 VIEW X 103 DSE X 104 RESZFL 105 FS? 25 106 GTO 08 107 CLX 108 SEEKPT 109 x<> L 110 BEEP 111 END Hope it can help someone! Best wishes from Brazil Artur ARTUR MARIO JUNIOR BRAZIL |
