(41CX/DM41)(17Bii) Date of the first Advent Sunday in a year
02-04-2020, 10:34 PM (This post was last modified: 02-04-2020 10:35 PM by jthole.)
This small program is an adaptation of an equation I have in my HP 17Bii. One of the reasons for posting this here, is that it shows the elegance of the HP 17Bii solver. The other reason is that it's fun, and can be useful (if only because you know when to open the first window of the Advent calendar ;-) ).
First of all, here is the short and simple HP 17Bii Solver equation: (both the solver and program assume DD.MMYYYY).
ADVDATE = DATE( L( XMAS : YEAR ÷ 1000000 + 25.12 ) : ( ( MOD( DDAYS( 1.0119 : G( XMAS ) : 1 ) : 7 ) + 22 ) x - 1 ) )
And here is the HP 41CX/DM41L program, which takes the year in the X register (just following the equation; maybe could be optimised further).
LBL "ADVDATE"
1000000
25.12
STO 00
1.0119
X<>Y
DDAYS  ;XROM 26,14
7
MOD
22
CHS
RCL 00
X<>Y
DATE+  ;XROM 26,13
END
Running on the 17Bii:
Enter YEAR: 2021
Solve ADVDATE: 28,112021
Running on the DM41L:
2021
XEQ ADVDATE
28,112021
Of course, the program (and equation) only works for the Gregorian calendar. Monday Jan. 1, 1900 was chosen because I liked that date (any date works, as long as you adjust the offset (currently 22) in the equation.
BTW; I do not have a HP 41CX, but I do have a SwissMicros DM41L; I tested the program on the DM41L.
11C, 12C, 17Bii, DM42
08-10-2020, 03:02 PM (This post was last modified: 08-10-2020 03:11 PM by ggauny@live.fr.)
RE: (41CX/DM41)(17Bii) Date of the first Advent Sunday in a year
I see your thread a little late but here is a little routine of mine I was using with my
HP 41c (+ time module) or my HP 41cx.
Instead of DDays I'm using DOW, but unfortunatly DOW gives 0 if the day is a sunday, (HP Prime gives 7). So we have to "adjust" in case of DOW gives a 0.
01 LBL "DIMAVENT'
02 7                        //Here is the adjust.
03 x<>y
04 1e6
05 /
06 25.12
07 +
08 ENTER
09 DOW
10 x=0?
11 x<> Z                 // or RCL+ ST Z on HP 42s, FREE42, DM42
12 21
13 +
14 CHS
15 DATE+
16 END
Of course runing on dm41, dm41x too and some other calculator.
2016 gives 27.112016 for example, 1582 gives 28.111582
In attachement I give 2 EXCEL calendars. May be usefull.
Have a good day.
Attached File(s)
.zip  AltCalFR.zip (Size: 60.56 KB / Downloads: 3)
.zip  AltCalItA.zip (Size: 58.93 KB / Downloads: 4)
Gérard.
08-11-2020, 08:03 AM (This post was last modified: 08-11-2020 02:29 PM by Werner.)
If you use 12.12 instead of 25.12, and change the 21 to 8, it will work for M.DY format as well.
[update] not quite.. but if you use 12.12, then do 13 DAYS+, then proceed as before, it will ;-)
[update #2] and if you take the first of January of the next year (which is always the same Day of Week as Christmas), it's even simpler:
 1E6
 1.01
 ENTER
 DOW
 7
 MOD
 35
 DATE+
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
01-22-2021, 01:27 PM
(08-10-2020 03:02 PM)ggauny@live.fr Wrote:  Hi,
01 LBL "DIMAVENT'
03 x<>y
04 1e6
05 /
06 25.12
07 +
08 ENTER
09 DOW
10 x=0?
12 21
13 +
14 CHS
15 DATE+
16 END
For HP Prime:
DATEADD((IP(Date)+.1225),-(21+DAYOFWEEK(IP(Date)+0.1225))) for actual year
SHIFT Define <function> for user defined function
HP 33C 34C 11C 41CX 12C 15C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more
01-24-2021, 05:00 AM
(08-10-2020 03:02 PM)ggauny@live.fr Wrote:  Instead of DDays I'm using DOW, but unfortunatly DOW gives 0 if the day is a sunday, (HP Prime gives 7).
No need to adjust, just shift the reference to Christmas Eve.
Better yet, reference to Dec 3, eliminated the need to subtract 21 days.
1st Advent Sunday = (Dec 3) - DOW(Dec 3) days       // Nov 27 to Dec 3
Code below assumed date format MM.DDYYYY
00 { 29-Byte Prgm }
01▸LBL "DIMAVEN"
02 1ᴇ6
03 ÷
04 12.03   ; Dec 3
05 +
06 ENTER
07 DOW
08 +/-
09 DATE+
10 END
Since DOW(Dec 3) = DOW(Dec 31), we can even do this in the head, using facts below:
1. Gregorian calendar repeat itself every 400 years.
2. DOW(Dec 31, 2000) = 0 (Sunday)
3. 365 days = 52 weeks + 1 day
Example, Year 2016:
2016 % 400 = 16
leap years count = IP(16/4) - IP(16/100) = 4
DOW(Dec 31, 2016) = (4 + 16) % 7 = 6
(Dec 3, 2016) - 6 days = Nov 27, 2016
Example, Year 2021:
2021 % 400 = 21
leap years count = IP(21/4) - IP(21/100) = 5
DOW(Dec 31, 2021) = (5 + 21) % 7 = 5
(Dec 3, 2021) - 5 days = Nov 28, 2021
01-24-2021, 10:35 AM
Hi Albert,
Thank for the optimisation !!!
Great.
Gérard.
