(41) Controlli in Cemento Armato (reinforced concrete checks)
02-22-2020, 12:20 PM
The attached article Un unico algoritmo per le verifiche a flessione, pressoflessione, tensoflessione di una sezione generica in c.a. parzialmente o interamente reagente A single algorithm for bending checks, pressure bending, tension bending of a generic section in reinforced concrete partially or entirely reagent from LA PREFABBRICAZIONE (COLLEGIO DEI TECNICI DELLA INDUSTRIALIZZAZIONE EDILIZIA) febbraio a.17/1981 {pgs 81-85} documents an HP-41 calculator routine "to unify the algorithms for the elastic test of a general section of reinforced concrete, submitted to combined tensile or compressive and (or) bending stress. It applies in the entire range of values of the stresses. The concrete section is schematized with an indefinite number of rectangles …"
FULLY documented contribution.
[attachment=8100]
BEST!
SlideRule
06-30-2020, 01:20 AM
RE: (41) Controlli in Cemento Armato (reinforced concrete checks)
Grazie!!! In Italian language!!!!!
