Perform two successive binary operations on same input
02-23-2020, 01:03 AM (This post was last modified: 02-23-2020 07:41 AM by cdmackay.)
[this is perhaps a little simplistic to be of interest, but…]
I often want to perform two successive binary operations (i.e. operations with two operands/arguments) on the same input, leaving the two results in the two lower stack levels.
An example might be finding the quotient and remainder (DIV/MOD) of two integers, on calculators that don't have a combined operation such as e.g 41/SandMath QREM, 50g IDIV2, Prime iquorem(). That often requires the first operation to be a binary operation followed by one or more unary operations, e.g. ÷ IP, followed by the second binary operation, e.g. MOD.
My clumsy efforts are as follows; I've not yet considered using STO/RCL methods, which might be useful if stack preserving was a requirement.
This is for interactive use; of course a program could be simpler.
I'd be interested in hearing of quicker/easier/more elegant methods.
RPN (stack not preserved)
Y ENTER ENTER X ENTER
R↓ x<>y R↓
<first binary operation>
<successive unary operations>
ENTER R↓ R↓                    # dup first result to Z
<second binary operation>
if the RPN example has just a single first binary operation, with no successive unary operations, it's much simpler:
Y ENTER ENTER X
x<>y
LASTX
RPL (uses stack levels 1–4)
Y X DUP2
3 ROLLD                        # move first result to level 3; alt: ROT ROT
if the RPL example has just a single first binary operation, with no successive unary operations, it's much simpler:
Y X
LASTARG
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot
Casio, Rockwell 18R
02-23-2020, 01:53 AM
RE: Perform two successive binary operations on same input
arg! I stupidly forgot that RPL LASTARG will restore both args, which makes the RPL case trivial; ah well.
Cambridge, UK
Casio, Rockwell 18R
02-23-2020, 01:55 AM (This post was last modified: 02-23-2020 02:02 AM by cdmackay.)
Although, LASTARG will only work if there's just one operation.
e.g. in my example, on many calcs the quotient requires two operations: ÷ IP, and so LASTARG won't restore the original Y X.
The RPL example in the first post will allow successive unary operations after the first binary operation.
Cambridge, UK
Casio, Rockwell 18R
02-23-2020, 07:34 AM
and there's a similar use of LASTX that can be used to simplify the RPN case, again if there's only the one binary operation. I'll edit that in too.
Cambridge, UK
Casio, Rockwell 18R
02-23-2020, 09:39 AM (This post was last modified: 02-23-2020 09:44 AM by Csaba Tizedes.)
(02-23-2020 01:03 AM)cdmackay Wrote:  I often want to perform two successive binary operations...
Sure! Check the attachment, there is my opinion about "Tricky-Genius-Programming-Style" - just as a practical engineer point of view...
So, with STO and RCL, with one flag and with lots of labels:
LBL A and LBL B: the two binary operation
LBL S: store the stack status
LBL T: store previous result
LBL R: restore the stack status
variable R: previous result
flag 0: set, if the stack X is the previous result
for the first running clear the flag 0
LBL A / LBL B
  XEQ S
  //do the binary operation on Y and X here; result in X
  SF 0 //it was an operation and the result is in X
  XEQ R //recover the stack
RTN
LBL S //store stack status
  FS0? //there is a result in X?
  XEQ T
  STO X
  x<>y
  STO Y
  x<>y
RTN
LBL T
  STO R
  Rdown
  CF0
RTN
LBL R //stack recovery
  RCL Y
  x<>y
  RCL X
  x<>y
RTN
Csaba
https://www.hpmuseum.org/forum/attachment.php?aid=8104
Attached File(s) Thumbnail(s)
02-23-2020, 04:10 PM
On the hp50g, I've done this several way depending on the desired operations. Sometimes I do things like (assuming two operands on the stack):
MAX LASTARG MIN
In other cases:
DUP2 "ops leaving single result" UNROT
I often need things like IDIV2 but that's so slow that IQUOT (or even / FLOOR) and MOD with LASTART or DUP2 are much faster.
02-23-2020, 05:23 PM
hah! very good, I agree Wink
thanks for all the suggestions, will study. forgot about UNROT too.
I've been mostly doing this interactive, so hadn't even thought about performance e.g. IDIV2, good point thanks!
Cambridge, UK
Casio, Rockwell 18R
