How translate code in .raw ?
03-10-2020, 10:36 AM
At Angel Martin and others experts in HP41.
Hello Sir, As expert in HP41 you are, May I ask you a help ? Well I have some binary or hexadecimal codes that I would like translate in .raw file for my V41 emulator, but I don't know to do this. Is existing program to do this translations ? If I know the method, I can translate you see ? Accept-you help me ? Thank in advance. Gérard GAUNY. The code I would like is : (a part of Julian Perry, Rubiks cube in 1982.) 01BBC000F20058133132331C193485C000F200591631325433 3485C000F2005A19311C1332333485C000F200540168678576 691B12423A71907311920E4113437190F2401640AEF32A970F B100A8159F067E11123F872AB10008F37F442C13B20009F37F 443A12B2000AF27F4411029010CE13CE12CE11CE10CE18CE1B CE1ACE199118719773B200850BF37F462C13B3000CF37F463A 12B3000DF27F461103689010CE11CE15CE1491109018CE1DCE 20CE1C9118119310921193159214921C9218769773B300850E F37F4C2C13B4000FF37F4C3A12B400CF0FF27F4C1104689011 CE12CE16CE1591119019CE1ECE21CE1D911911931192129316 9215921D9219769773B40085CF10F37F422C13B500CF11F37F 423A12B500CF12F27F421105689012CE13CE17CE169112901A CE1FCE22CE1E911A119312921393179216921E921A769773B5 0085CF13F37F522C13B600CF14F37F523A12B600CF15F27F52 1106689013CE10CE14CE179113901BCE1CCE23CE1F911B1193 13921093149217921F921B769773B60085CF16F37F552C13B7 00CF17F37F553A12B700CF18F27F5511079014CE15CE16CE17 CE14CE20CE21CE22CE239120719773B700C0000DBC Gérard. |
03-10-2020, 11:23 AM
RE: How translate code in .raw ?
The xxd program will do what you are looking for; it can create hex dumps of binary data, and also do the reverse:
Code: $ xxd -r -p > foo.raw << EOF On Linux and MacOS, this is standard equipment; on Windows, you may need Cygwin, or build it from source. |
03-10-2020, 01:15 PM
You can also use the following on-line translator that will create a binary file from you hexadecimal strings: Hexadecimal -> file (binary)
Copy/paste the hexadecimal code to the Hex string input form, choose a file name ending in .raw, click on convert and save the result file. That’s all. |
03-11-2020, 07:05 AM
(This post was last modified: 03-11-2020 07:07 AM by Ángel Martin.)
The RUBIKS module including Julian Perry's programs is available at TOS and in the CL Library; the FOCAL programs can be printed or even COPYed from the ROM.
I still use Leo Duran's "UserCode" utilities for my TEXT <-> RAW conversions, it may be useful to you as well. |
03-11-2020, 08:17 AM
Hi at you,
Many thank you for you help ! I'am going to try. Gérard. |
