Condition Number of a Function
03-16-2020, 06:31 AM
Condition number for a function f(x) is:
Cond = abs( x * d/dx f(x) / f(x) )
If the condition number is low, then function is not sensitive to small changes. This is similar to the condition number for matrices, where a low number gives for a well-conditioned problem while a higher number gives for an ill-conditioned problem.
HP Prime Program CONDFX
Arguments: f(X) as a string, use the capital X as a variable; a: value
Syntax: CONDFX(f, a)
EXPORT CONDFX(f,a)
// f(X) as a string, x0
// 2020-02-06 EWS
X:=a;
fx:=EXPR(f);
X:=a+.0001;
dx:=(EXPR(f)-fx)/.0001;
c:=ABS(a*dx/fx);
RETURN c;
Note: The derivative is calculated manually.
Example: (in Radians mode)
CONDFX("2*X*COS(X)",1.5) returns 20.15361502
CONDFX("e^-(.25*X)",1.5) returns 0.374995308312
Blog link: http://edspi31415.blogspot.com/2020/03/h...ition.html
