Resizing the display on a HP-50g
04-10-2020, 05:06 PM
Hello all,
How can I make the display on an HP-50g larger than the standard 131x80 pixels, stack or graph grob? In the documentation I have, the command XYGROBDISP is recommended for this, but it still corrupts memory. Can anyone help me with this problem? Sincerely, Karel.
I use HP-16C, WP-34S emulator, HP-35s, HP-48GX, HP-50g, and HP Prime G2.
04-11-2020, 09:40 AM
RE: Resizing the display on a HP-50g
I think you can watch the PDIM command (22-20 user guide).
Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50
04-13-2020, 09:46 PM
(04-11-2020 09:40 AM)franz.b Wrote:  I think you can watch the PDIM command (22-20 user guide).
Hi Franz,
Thanks for your comment. The system RPL command makepict# is the core of the user RPL command PDIM. I looked it up in the documentation I have, and it might work. I did not implement it because I have already found another solution to my problem, but thank you for your contribution. However, I may be able to use this system RPL command for another project in the future. Sincerely, Karel.
