Good day.
Wrote program which finally shall be used as star finder (120 nav stars) and finally shall draw Line of Position from given stars.
First part of the program (star finder) is done but facing some issues.
1. To use the program first You have to create spreadsheet STARDAT. This spreadsheet is used as storage of data and easy tool to manipulate some data further. Generally spreadsheet could be avoided as i could do the same manipulating only lists within the program. I just did it to have easier view of data and to learn how to manipulate list and spreadsheets)
2. Once the program is executed first time please make sure You enter at least year (between 1986 and 2050) and any month and date. Other fields may remain "0"
3. Go back to STARDAT and in column I enter formula"=5.3-(F:F)" and in column J please enter formula "=sqr(I:I)". This is required to have proper magnitude of the stars to be displayed. (magnitude range is between 0 and 5.23)
4. Now the program shall run properly on stars shall be displayed one by one (only stars above horizon). The idea is while taking sights by sextant - You may get as well observed aprox azimuth so while passing through displayed stars - You may know which star was taken. This shall be noted down to enter further data for LOP.
5. The name of the star is dimmed after each ENTER due to fact they are overlapping sometimes and difficult to read on small screen. So in attached screenshot You see blue dimmed stars already.
Now the problem starts.
1. The program is used on HP android emulator Galaxy Note 9 so would like to write program with MOUSE function to touch the star with stylus and choose the star for further LOP, 9choise to be shifted to new list for further LOP). I have no idea how to do this
2. Problem is the program runs only if earlier the STARDAT spreadsheet was viewed from Application screen. Otherwise if as example I view Adv Graphing application - error appear. I have no idea how to tell program to avoid this error.
EXPORT AASTRO()
LOCAL A,B,C,D,E,F,G,H;
LOCAL YR,MN,DA,si,dip;
LOCAL I,L1,L2,L3,L4,L5,L6,L10;
LOCAL L11,L12,L13,L14,L15,L10:={};
LOCAL L11:={},L12:={},L13:={},L14:={},L15:={};
PRINT();
I:=1;
L1:={"Acamar","Achernar","Acrux","Adhara","Albaldah","Albireo","Alcyone","Aldebaran","Alderamin","Algenib","Algieba","Algol","Algorab","Alhena","Alioth","Alkaid","Almaak","Alnair","Alnath","Alnilam","Alnitak","Alphard","Alphekka","Alpheratz","Altair","Aludra","Ankaa","Antares","Arcturus","Arneb","Atria","Avior","Becrux","Bellatrix","Betelgeuse","Canopus","Capella","Caph","Castor","Cebalrai","Cih","CorCaroli","Cursa","Deneb","Denebola","Diphda","Dschubba","Dubhe","Enif","Etamin","Fomalhaut","Gacrux","Gienah","GienahGhurab","Gomeisa","Graffias","Hadar","Hamal","Hassaleh","Hatsya","Izar","KausAustralis","KausBorealis","KausMeridionalis","Kochab","Kornephoros","Kraz","Markab","Matar","Menkalinan","Menkar","Menkent","Merak","Miaplacidus","Mintaka","Mirach","Mirphak","Mirzam","Mizar","Mufrid","Naos","Nash","Nihal","Nunki","Peacock","Phad","Phakt","Polaris","Pollux","Porrima","Procyon","RasElasedAustralis","Rasalgethi","Rasalhague","Rastaban","Regulus","Rigel","RigilKentaurus","Ruchbah","Sadalmelik","Sadalsuud","Sadr","Saiph","Sargas","Scheat","Shaula","Shedir","Sheratan","Sirius","Spica","Tarazed","Tureis","Unukalhai","Vega","Vindemiatrix","Wezen","Zaurak","Zosma","Zubenelgenubi","Zubeneschemali"};
L2:={2.971026667,1.628556,12.443311,6.977097,19.162731,19.512023,3.79141,4.598677,21.30963,0.220598,10.332873,3.136148,12.497739,6.628528,12.900472,13.792354,2.064984,22.137209,5.438198,5.603559,5.679313,9.45979,15.578128,0.139791,19.846388,7.401584,0.438056,16.490128,14.26103,5.545504,16.811077,8.375236,12.795359,5.418851,5.919529,6.399195,5.27815,0.152887,7.576634,17.724543,0.945143,12.933807,5.130829,20.690532,11.817663,0.72649,16.005557,11.062155,21.736433,17.943437,22.960838,12.519429,20.770178,12.263437,7.452512,16.09062,14.063729,2.119555,4.949894,5.590551,14.749784,18.402868,18.466179,18.3499,14.845105,16.503668,12.573121,23.079348,22.716704,5.992149,3.037992,14.111395,11.030677,9.220041,5.533445,1.162194,3.405378,6.378329,13.398747,13.911411,8.059737,18.096803,5.470756,18.92109,20.427459,11.897168,5.660817,2.52975,7.755277,12.694345,7.655033,9.764188,17.244127,17.582241,17.507213,10.139532,5.242298,14.660765,1.430216,22.096399,21.525982,20.370473,5.795941,17.62198,23.062901,17.560145,0.675116,1.910668,6.752481,13.419883,19.770994,9.284838,15.737798,18.61564,13.036278,7.139857,3.967157,11.235138,14.847977,15.283449};
L3:={-40.30471389,-57.236757,-63.099092,-28.972084,-21.023615,27.959681,24.105137,16.509301,62.585573,15.183596,19.841489,40.955648,-16.515432,16.399252,55.959821,49.313265,42.329725,-46.960975,28.60745,-1.20192,-1.942572,-8.658603,26.714693,29.090432,8.868322,-29.303104,-42.305981,-26.432002,19.18241,-17.822289,-69.027715,-59.509483,-59.688764,6.349702,7.407063,-52.69566,45.997991,59.14978,31.888276,4.567303,60.71674,38.31838,-5.086446,45.280338,14.57206,-17.986605,-22.62171,61.751033,9.875011,51.488895,-29.622236,-57.113212,33.970256,-17.541929,8.289315,-19.805453,-60.373039,23.462423,33.16609,-5.909901,27.074222,-34.384616,-25.4217,-29.828103,74.155505,21.489613,-23.396759,15.205264,30.221245,44.947433,4.089734,-36.369954,56.382427,-69.717208,-0.299092,35.620558,49.86118,-17.955918,54.925362,18.397717,-40.003148,-30.424091,-20.759441,-26.296722,-56.73509,53.69476,-34.074108,89.264109,28.026199,-1.449375,5.224993,23.774255,14.390333,12.560035,52.301387,11.967207,-8.20164,-60.833976,60.235283,-0.319851,-5.571172,40.256679,-9.669605,-42.997824,28.082789,-37.103821,56.537331,20.808035,-16.716116,-11.161322,10.613261,-59.275229,6.425627,38.783692,10.95915,-26.3932,-13.508515,20.523717,-16.041778,-9.382917};
L4:={-0.0446,0.08802,-0.03537,0.00263,-0.00117,-0.00709,0.01935,0.06278,0.14991,0.0047,0.31077,0.00239,-0.20997,-0.00204,0.11174,-0.12123,0.04308,0.1276,0.02328,0.00149,0.00399,-0.01449,0.12038,0.13568,0.53682,-0.00376,0.23276,-0.01016,-1.09345,0.00327,0.01785,-0.02534,-0.04824,-0.00875,0.02733,0.01999,0.07552,0.52339,-0.20633,-0.04067,0.02565,-0.23343,-0.08339,0.00156,-0.49902,0.23279,-0.00867,-0.13646,0.03002,-0.00852,0.32922,0.02794,0.35616,-0.15958,-0.05028,-0.00675,-0.03396,0.19073,0.00363,0.00227,-0.05065,-0.03961,-0.04481,0.02996,-0.03229,-0.09843,0.00086,0.0611,0.01311,-0.05641,-0.01181,-0.51929,0.08166,-0.15766,0.00167,0.17559,0.02411,-0.00345,0.12123,-0.06095,-0.03082,-0.05575,-0.00503,0.01387,0.00771,0.10776,-0.0001,0.04422,-0.62569,-0.61666,-0.71657,-0.04609,-0.00671,0.11008,-0.01559,-0.2494,0.00187,-3.67819,0.29724,0.0179,0.02279,0.00243,0.00155,0.00606,0.18776,-0.0089,0.05036,0.09632,-0.54601,-0.0425,0.01572,-0.01903,0.13466,0.20102,-0.27505,-0.00275,0.06051,0.14331,-0.10569,-0.09639};
L5:={0.019,-0.04008,-0.01473,0.00229,-0.03683,-0.00563,-0.04311,-0.18936,0.04827,-0.00824,-0.15288,-0.00144,-0.1393,-0.06692,-0.00899,-0.01556,-0.05085,-0.14791,-0.17422,-0.00106,0.00254,0.03325,-0.08944,-0.16295,0.38554,0.00666,-0.35364,-0.02321,-1.9994,0.00154,-0.03292,0.02272,-0.01282,-0.01328,0.01086,0.02367,-0.42713,-0.18042,-0.14818,0.1588,-0.00382,0.05498,-0.07544,0.00155,-0.11378,0.03271,-0.0369,-0.03525,0.00138,-0.02305,-0.16422,-0.26433,0.33028,0.02231,-0.03845,-0.02489,-0.02506,-0.14577,-0.01854,-0.00062,0.02,-0.12405,-0.18629,-0.02638,0.01191,-0.01449,-0.056,-0.04256,-0.02611,-0.00088,-0.07876,-0.51787,0.03374,0.10891,0.00056,-0.11223,-0.02601,-0.00047,-0.02201,-0.3581,0.01677,-0.18153,-0.08592,-0.05265,-0.08615,0.01116,-0.02405,-0.01174,-0.04595,0.06066,-1.03458,-0.00957,0.03278,-0.22261,0.01157,0.00491,-0.00056,0.48184,-0.04949,-0.00993,-0.0067,-0.00093,-0.0012,-0.00095,0.13761,-0.02995,-0.03217,-0.1088,-1.22308,-0.03173,-0.00308,0.01311,0.04414,0.28746,0.01996,0.00333,-0.11134,-0.13043,-0.069,-0.02076};
L6:={2.88,0.45,0.77,1.5,2.88,3.05,2.85,0.87,2.45,2.83,2.01,2.09,2.94,1.93,1.76,1.85,2.1,1.73,1.65,1.69,1.74,1.99,2.22,2.07,0.76,2.45,2.4,1.06,-0.05,2.58,1.91,1.86,1.25,1.64,0.45,-0.62,0.08,2.28,1.58,2.76,2.15,2.89,2.78,1.25,2.14,2.04,2.29,1.81,2.38,2.24,1.17,1.59,2.48,2.58,2.89,2.56,0.61,2.01,2.69,2.75,2.35,1.79,2.82,2.72,2.07,2.78,2.65,2.49,2.93,1.9,2.54,2.06,2.34,1.67,2.25,2.07,1.79,1.98,2.23,2.68,2.21,2.98,2.81,2.05,1.94,2.41,2.65,1.97,1.16,2.74,0.4,2.97,2.78,2.08,2.79,1.36,0.18,-0.01,2.66,2.95,2.9,2.23,2.07,1.86,2.44,1.62,2.24,2.64,-1.44,0.98,2.72,2.21,2.63,0.03,2.85,1.83,2.97,2.56,2.75,2.61};
FOR I FROM 1 TO 120 DO
STARDAT.Cell(I,1):=L1(I);
STARDAT.Cell(I,2):=L2(I);
STARDAT.Cell(I,3):=L3(I);
STARDAT.Cell(I,4):=L4(I);
STARDAT.Cell(I,5):=L5(I);
STARDAT.Cell(I,6):=L6(I);
INPUT({A,B,C,D,E,F,G},"Enter data",{"Air temp","Sea temp","Pressure","Eye height","Time of obs","Lattitude","Longitude"});
INPUT({YR,MN,DA,si},"Enter data",{"Year","Month","Day","Sext index err"});
LOCAL ho,min,sec;
si:=si/60;
dip:=(-1.76*√(D)+.34*(A-B)-.2)/60;
E:=HMS→(E);
ho:=IP(E);
min:=IP(FP(E)*60);
sec:=IP(FP(FP(E)*60)*60);
LOCAL a,b,JD,DF;
DF:=DA+(ho*3600+min*60+sec)/86400;
IF (MN=1 OR MN=2)
THEN
YR:=YR-1;
MN:=MN+12
IF YR*100+MN+DF>=158225
THEN
a:=IP(ABS(YR/100));
b:=2-a+IP(a/4);
ELSE
b:=0
JD:=IP(365.25*(YR+4716))+IP(30.6001*(MN+1))+DF+b-1524.5;
LOCAL k,dt,dfdt,jde,tau,t,to;
k:=YR+(MN-.5)/12-2000;
//below dt only for period 1986 2050
IF YR≤2005 THEN
63.86+k*(.3345+k*(-.060374+k*(.0017275+k*(.000651814+.00002373599))))▶dt;
ELSE
62.92+k*(.32217+.005589*k)▶dt
dfdt:=DA+(ho*3600+min*60+sec+dt)/86400;
DA:=DA+(ho*3600+min*60+sec)/86400;
jde:=IP(365.25*(YR+4716))+IP(30.6001*(MN+1))+dfdt+b-1524.5;
tau:=(jde-2451545)/365250;
t:=tau*10;
to:=t*100;
0▶HAngle;
LOCAL lo,lp,om,dp,npsid,npsir,deps,epsor;
LOCAL de,nepsd,nepsr,epsr,g,gasd,gastd;
lo:=(280.4665+36000.7698*t)*π/180;
lp:=(218.3165+481267.8813*t)*π/180;
om:=(125.04452-1934.136261*t)*π/180;
dp:=-17.2*SIN(om)-1.32*SIN(2*lo)-.23*SIN(2*lp)+.21*SIN(2*om);
npsid:=dp/3600;
npsir:=npsid*π/180;
deps:=t*(-46.815*t*(-.000059+.001813*t));
epsor:=(23.4392911+deps/3600)*π/180;
de:=9.2*COS(om)+.57*COS(2*lo)-.1*COS(2*lp)-.09*COS(2*om);
nepsd:=de/3600;
nepsr:=nepsd/3600;
epsr:=epsor+nepsr;
g:=280.46061837+360.98564736629*(JD-2451545)+(t^2)*(0.000387933-t/38710000);
gasd:=g+npsid*COS(epsr);
gastd:=gasd-IP(gasd/360)*360;
gastd:=→HMS(gastd);
//PRINT("Gha ɤ for time ");
E:=→HMS(E);
//PRINT(E);
//PRINT(gastd);
gastd:=HMS→(gastd);
LOCAL zr,zd,td,tr,lm,md;
LOCAL mr,ca,cb,cc,ccc;
LOCAL zde,ls,lsd,lsr,ec,pp,pr,pd;
1▶HAngle;
zde:=t*(2306.2181+t*(.30188+t*.017998))/3600;
zr:=zde*π/180;
zd:=t*(2306.2181+t*(1.09468+t*.018203))/3600;
td:=t*(2004.3109-t*(.42665+t*.041833))/3600;
tr:=td*π/180;
lm:=280.46646+t*(36000.76983+t*0.0003032);
md:=357.52911+t*(35999.05029-t*.0001537);
mr:=md*π/180;
ca:=1.914602-t*(.004817+t*.000014);
cb:=.019993-t*(.000101);
cc:=.000289;
0▶HAngle;
ccc:=ca*SIN(mr)+cb*SIN(2*mr)+cc*SIN(3*mr);
1▶HAngle;
ls:=ccc+lm;
lsd:=ls-360*IP(ls/360);
lsr:=lsd*π/180;
ec:=.016708634-t*(.000042037+.0000001267*t);
pp:=102.93735+t*(1.71946+.000464);
pd:=pp-360*IP(pp/360);
pr:=pd*π/180;
I:=1;
L1(I):=STARDAT.Cell(I,2);
L2(I):=STARDAT.Cell(I,3);
L3(I):=STARDAT.Cell(I,4);
L4(I):=STARDAT.Cell(I,5);
LOCAL L16:={},L17:={},L18:={},L19:={};
LOCAL L20:={},L21:={},L22:={},L23:={};
LOCAL L24:={},L25:={},L26:={},L27:={};
LOCAL L28:={},L29:={},L30:={},L31:={};
LOCAL L32:={},L33:={},L34:={},L35:={};
LOCAL L36:={},L37:={},L38:={},L39:={};
LOCAL L40:={},L41:={},L42:={};
0▶HAngle;
L6:=L1*15;
L7:=L6+L3/3600*to;
L8:=L2+L4/3600*to;
L12:=L7*π/180;
L13:=L8*π/180;
L9:=COS(L13)*SIN(L12+zr);
L10:=COS(tr)*COS(L13)*COS(L12+zr)-SIN(tr)*SIN(L13);
L11:=SIN(tr)*COS(L13)*COS(L12+zr)+COS(tr)*SIN(L13);
0▶HAngle;
I:=1;
atan2(L9(I),L10(I));
CASE
if L10(I)==0 AND L9(I)==0 then "undefined"; end;
if L10(I)>0 then L14(I):=(atan(L9(I)/L10(I))/π*180)+zd; end;
if L10(I)<0 AND L9(I)>=0 then L14(I):=(atan(L9(I)/L10(I))/π*180)+180+zd; end;
if L10(I)==0 AND L9(I)>0 then L14(I):=pi/2; end;
if L10(I)<0 AND L9(I)<=0 then L14(I):=(atan(L9(I)/L10(I))/π*180)-180+zd; end;
if L10(I)==0 AND L9(I)<0 then L14(I):=-pi/2; end;
1▶HAngle;
I:=1;
L15(I):=L14(I)-360*FLOOR(L14(I)/360)
L16:=ASIN(L11)/π*180;
L17:=L16*π/180;
//PRINT("L17");
//PRINT(L17);
L18:=L15*π/180;
//PRINT("L18");
//PRINT(L18);
0▶HAngle;
L19:=SIN(epsr)*COS(L18)*npsir+SIN(L18)*nepsr;
//PRINT("L19");
//PRINT(L19);
L20:=(COS(epsr)+SIN(epsr)*SIN(L18)*TAN(L17))*npsir-COS(L18)*TAN(L17)*nepsr;
L21:=COS(L18)*COS(pr)*COS(epsr)+SIN(L18)*SIN(pr);
L22:=COS(L18)*COS(lsr)*COS(epsr)+SIN(L18)*SIN(lsr);
L23:=(ec*L21-L22)*.0000993650849745/COS(L17);
L24:=COS(pr)*COS(epsr)*(TAN(epsr)*COS(L17)-SIN(L18)*SIN(L17))+COS(L18)*SIN(L17)*SIN(pr);
L25:=COS(lsr)*COS(epsr)*(TAN(epsr)*COS(L17)-SIN(L18)*SIN(L17))+COS(L18)*SIN(L17)*SIN(lsr);
L26:=(ec*L24-L25)*.0000993650849745;
//PRINT("L26");
//PRINT(L26);
1▶HAngle;
L27:=(L23+L20+L18)/(π)*180;
//PRINT("L27");
//PRINT(L27);
L28:=360-L27;
L29:=((L26+L19+L17)/π)*180;
//PRINT("L29");
//PRINT(L29);
0▶HAngle;
L39:=gastd+L28-IP((gastd+L28)/360)*360;
L39:=L39*π/180;
//PRINT("L39");
//PRINT(L39);
LOCAL lol,lod,lom,los,lat,lad,lam,las;
F:=HMS→(F);//Lat
G:=HMS→(G);//Long
lod:=IP(G);
lom:=IP(FP(G)*60);
los:=IP(FP(FP(G)*60)*60);
lol:=los/3600+lom/60+lod;
lol:=lol*π/180;
//PRINT("Long");
//PRINT(lol);
lad:=IP(F);
lam:=IP(FP(F)*60);
las:=IP(FP(FP(F)*60)*60);
lat:=las/3600+lam/60+lad;
lat:=lat*π/180;
//PRINT("Lat");
//PRINT(lat);
//WAIT();
L40:=L39+lol;
//PRINT("L40");
//PRINT(L40);
L41:=L40/(π)*180;
//PRINT("L41");
//PRINT(L41);
L30:=L41-IP(L41/360)*360;
//PRINT("L30");
//PRINT(L30);
1▶HAngle;
L33:=L29*π/180;
//PRINT("L33");
//PRINT(L33);
0▶HAngle;
L36:=(SIN(L33)*SIN(lat)+COS(L33)*COS(lat)*COS(L40));
//PRINT("L36");
//PRINT(L36);
1▶HAngle;
L34:=ASIN(L36)*π/180;
//PRINT("L34");
//PRINT(L34);
//lat:=lat*π/180;
0▶HAngle;
L35:=(SIN(L33)-SIN(lat)*L36)/(COS(lat)*COS(L34));
//PRINT("L35");
//PRINT(L35);
1▶HAngle;
L31:=L34*180/π;
//PRINT("L31");
//PRINT(L31);
L37:=(ACOS(L35));
//PRINT("L37");
//PRINT(L37);
I:=1;
IF L30(I)>180 THEN
L38(I):=L37(I);
ELSE
L38(I):=360-L37(I);
LOCAL dip;
L42:=((C-1010)*(1.0367/(1+.00367+A))+TAN(L31+7.31/(L31+4.4)))/60;
I:=1;
STARDAT.Cell(I,7):=L38(I);
STARDAT.Cell(I,8):=L31(I);
//PRINT("L38");
//PRINT(L38);
//KILL;
//STARTVIEW(1);
PRINT();
LOCAL mag;
INPUT({mag},"Enter magnitude",{"Value 0-3 (Recomended 2)"});
RECT();
//LOCAL Xmin,Xmax,Ymin,Ymax;
LINE_P(0,90*2.43,360/1.125,90*2.43,RGB(255,0,225));
LINE_P(0,180*2.43,360/1.125,180*2.43,RGB(255,0,225));
LINE_P(180/1.125,0,180/1.125,180*2.43,RGB(255,0,0));
LINE_P(90/1.125,0,90/1.125,90*2.43,RGB(255,0,0));
LINE_P(270/1.125,0,270/1.125,219,RGB(255,0,0));
LINE_P(45/1.125,0,45/1.125,90*2.43,RGB(255,0,225));
LINE_P(135/1.125,0,135/1.125,219,RGB(255,0,225));
LINE_P(225/1.125,0,225/1.125,219,RGB(255,0,225));
LINE_P(315/1.125,0,315/1.125,90*2.43,RGB(255,0,225));
LINE_P(358/1.125,0,358/1.125,219,RGB(255,0,225));
TEXTOUT_P("AZYM",2,0,1);
TEXTOUT_P("45°",45/1.125,0,1);
TEXTOUT_P("90°",90/1.125,0,1);
TEXTOUT_P("135°",135/1.125,0,1);
TEXTOUT_P("180°",180/1.125,0,1);
TEXTOUT_P("225°",225/1.125,0,1);
TEXTOUT_P("270°",270/1.125,0,1);
TEXTOUT_P("315°",315/1.125,0,1);
LINE_P(0,15*2.43,360/1.125,15*2.43,RGB(255,0,225));
LINE_P(0,30*2.43,360/1.125,30*2.43,RGB(255,0,225));
LINE_P(0,45*2.43,360/1.125,45*2.43,RGB(255,0,225));
LINE_P(0,60*2.43,360/1.125,60*2.43,RGB(255,0,225));
LINE_P(0,75*2.43,360/1.125,75*2.43,RGB(255,0,225));
TEXTOUT_P("75°",0,15*2.43,1);
TEXTOUT_P("60°",0,30*2.43,1);
TEXTOUT_P("45°",0,45*2.43,1);
TEXTOUT_P("30°",0,60*2.43,1);
TEXTOUT_P("15°",0,75*2.43,1);
TEXTOUT_P("Hz",0,90*2.43,1);
I:=1;
IF (STARDAT.Cell(I,8))>0 AND (STARDAT.Cell(I,6))<mag THEN
PIXON_P((STARDAT.Cell(I,7)/1.125),220-(STARDAT.Cell(I,8)*2.43));
ARC_P((STARDAT.Cell(I,7)/1.125),220-(STARDAT.Cell(I,8)*2.43),(STARDAT.Cell(I,10))*2,2*π,RGB(255,0,255));
TEXTOUT_P((STARDAT.Cell(I,1)),(STARDAT.Cell(I,7)/1.125)-20,220-(STARDAT.Cell(I,8)*2.43)+3,1,RGB(0,0,255));
WAIT();
TEXTOUT_P((STARDAT.Cell(I,1)),(STARDAT.Cell(I,7)/1.125)-20,220-(STARDAT.Cell(I,8)*2.43)+3,1,RGB(255,255,255));
WAIT();
1▶I;
LOCAL NM,DD,L50:={},L51:={},L52:={};
LOCAL L53:={},L54:={},L55:={},L56:={};
LOCAL mnm,mns,hod,hom;
INPUT({NM},"Enter data",{"How many stars"});
FOR I FROM 1 TO NM DO
CHOOSE(DD,"Choose star",{"Acamar","Achernar","Acrux","Adhara","Albaldah","Albireo","Alcyone","Aldebaran","Alderamin","Algenib","Algieba","Algol","Algorab","Alhena","Alioth","Alkaid","Almaak","Alnair","Alnath","Alnilam","Alnitak","Alphard","Alphekka","Alpheratz","Altair","Aludra","Ankaa","Antares","Arcturus","Arneb","Atria","Avior","Becrux","Bellatrix","Betelgeuse","Canopus","Capella","Caph","Castor","Cebalrai","Cih","CorCaroli","Cursa","Deneb","Denebola","Diphda","Dschubba","Dubhe","Enif","Etamin","Fomalhaut","Gacrux","Gienah","GienahGhurab","Gomeisa","Graffias","Hadar","Hamal","Hassaleh","Hatsya","Izar","KausAustralis","KausBorealis","KausMeridionalis","Kochab","Kornephoros","Kraz","Markab","Matar","Menkalinan","Menkar","Menkent","Merak","Miaplacidus","Mintaka","Mirach","Mirphak","Mirzam","Mizar","Mufrid","Naos","Nash","Nihal","Nunki","Peacock","Phad","Phakt","Polaris","Pollux","Porrima","Procyon","RasElasedAustralis","Rasalgethi","Rasalhague","Rastaban","Regulus","Rigel","RigilKentaurus","Ruchbah","Sadalmelik","Sadalsuud","Sadr","Saiph","Sargas","Scheat","Shaula","Shedir","Sheratan","Sirius","Spica","Tarazed","Tureis","Unukalhai","Vega","Vindemiatrix","Wezen","Zaurak","Zosma","Zubenelgenubi"});
L50(I):=DD;
//END;
//FOR I FROM 1 TO NM DO
INPUT({mnm,mns,hod,hom},STARDATA.Cell(L50(I),1),{"Min of obs","Sec of obs","Ho deg°","Ho min'"});
L51(I):=(mns/3600)+(mnm/60);
L52(I):=hod+hom/60;
//PRINT(L50);
I:=1;
PRINT(STARDAT.Cell(L50(I),1));
PRINT(L51);
PRINT(L52);
L42:=((C-1010)*(1.0367/(1+.00367+A))+TAN(L31+7.31/(31+4.4)))/60;
//PRINT("refr");
//PRINT(L42);
