More lines on 48G display?
04-12-2020, 06:23 PM
Is there a way to increase the number of lines displayed on 48G? I'm sure I did this at one point (perhaps it was a different model), but can't find anything about doing so in the manual (the version I have is not searchable, so I may have missed it).
Is there a way to do this? Am I remembering a different model (I'm sure it had a similar display, e.g. I can clearly picture { HOME } being present)? |
04-12-2020, 06:30 PM
RE: More lines on 48G display?
Why would you want to do that? The display is hardly readable as it is now (even before I needed to wear reading glasses...) so squeezing in more lines using the existing pixels will make it completely useless. The only way to do that would be to remove the display and use a modern OLED mobile phone display instead... Regards Max |
04-12-2020, 09:14 PM
RE: More lines on 48G display? | |||
04-12-2020, 09:16 PM
I think Metakernel and/or SpeedUI let you change the stack font. But I'm not sure the 48G has enough space to install either.
04-12-2020, 09:28 PM
I think you are looking for this:
https://www.hpcalc.org/details/2645 Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50 |
04-12-2020, 09:30 PM
(04-12-2020 09:28 PM)franz.b Wrote: I think you are looking for this: Nice! Now I just need to figure out how to install that! (New to this.) |
04-13-2020, 01:54 AM
Along with the one franz mentioned, there are a number of "stack replacement" programs at hpcalc.org. Some of them are quite small in size.
https://www.hpcalc.org/hp48/utils/stack/ |
04-13-2020, 07:38 AM
Look for the MetaKernel, it is the ultimate in this... But it is rather large and requires a memory card all to itself... However, it does much more than just give you more stack level, it includes a new editor, a new matrix, equation and graphic editor. It also has a bunch of development tools build in... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-13-2020, 01:15 PM
04-13-2020, 02:00 PM
MetaKernel is available for download here: https://www.hpcalc.org/details/213
You'll need a serial cable and a 128 KB card in port 1. So it will only work with a 48GX or 48G with memory extension. |
04-13-2020, 02:04 PM
(04-13-2020 02:00 PM)SammysHP Wrote: You'll need a serial cable... Is it available anywhere already on a ROM card (as described here)? |
04-13-2020, 03:05 PM
(04-12-2020 09:16 PM)Dave Britten Wrote: I think Metakernel and/or SpeedUI let you change the stack font. But I'm not sure the 48G has enough space to install either.Yep. SpeedUI lets you choose between up to four different font sizes. There is an ultra lite version of SpeedUI which will fit into a normal 48G with only 32K of RAM. Of course that reduced version lacks many features of the full version;-) -- Ray |
04-13-2020, 05:55 PM
(04-12-2020 06:23 PM)Orome Wrote: Is there a way to increase the number of lines displayed on 48G? For minimum size, I really like HP Sauce MILD by André Schoorl I have that running on several HP 48g's where size is critical and MetaKernel Won't fit. 17bii | 32s | 32sii | 41c | 41cv | 41cx | 42s | 48g | 48g+ | 48gx | 50g | 30b |
04-14-2020, 05:26 AM
(04-13-2020 02:04 PM)Orome Wrote:(04-13-2020 02:00 PM)SammysHP Wrote: You'll need a serial cable... New cards are of course out of the question... Can you find a 2nd hand one? maybe? I do not know... I don't even think that I have one myself! Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
