(42) Double precision summation and DOT
04-14-2020, 08:38 AM
works in all flavors of the 42, mainly as test cases for Thomas' FMA-rewrite of all internal DOT functions. For the 42S, change all LSTO instructions to STO.
It works using subroutines that will: - add two single-precision numbers and produce a double-precision number (S+) - multiply two single-precision numbers and produce a double-precision number (Sx) - add two double-precision numbers (D+) These routines are bundled in the file double.raw I've added my notes on these, for those who want more details. The double precision summation and DOT functions are in SUMDOT.raw. They will return double-precision numbers (heads in Y, tails in X) listings: Code: 00 { 93-Byte Prgm } Code: 00 { 154-Byte Prgm } Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
04-14-2020, 02:35 PM
RE: (42) Double precision summation and DOT
Quote:0.9 SQRT X^2 0.9 - produces 10^-n, where n=12 for a real 42S and 34 for Free42 Decimal. This is just lucky. For decimal precision P, many times it just return 0. Code: P "0.9 SQRT X^2 0.9 -" Kahan suggest a better way, "Matlab’s Loss is Nobody’s Gain", page 5 ULP = abs((4/3 - 1)*3 – 1) round(4/3 - 1) has error of 1/3 ULP (exactly), under both decimal and binary version Example: Free42Binary.exe: ULP = 2^-52 ≈ 2.22E-16 → precision = 53 bits Free42Decimal.exe: ULP = 1E-33 → precision = 34 decimals |
04-14-2020, 03:07 PM
Double precision trick assumed round-to-nearest (so sign bit can hold a bit), halfway-to-even.
However, for decimal version, this also meant sign can only hold 1 bit. Thus, decimal version with odd digits precision cannot be split accurately this way ... Also, no internal extra precision (unless it were rounded with half-way-to-odd), to avoid double-rounding issues. Code: #include <stdio.h> Above code demonstrated problems of double-rounding. Compile code with gcc v.7.1.0 (included with Strawberry Perl), Win7, no optimization > gcc -otest test.c > test 2 3 4 The reason for the discrepancy can be seen from the bits: b = 1e16 + 2.9999 = 0b100011100001101111001001101111110000010000000000000010.1111111111111001 ... round(b, 53-bits) = 1e16 + 2 round(b, 64-bits) = 1e16 + 3 round(round(b, 64-bits), 53-bits) = 1e16 + 4 Reference: To SSE, or not to SSE, that is the question GNU Linux and the Extended Precision on x86 Processors |
04-14-2020, 04:20 PM
(04-14-2020 02:35 PM)Albert Chan Wrote:Quote:0.9 SQRT X^2 0.9 - produces 10^-n, where n=12 for a real 42S and 34 for Free42 Decimal. Hello Albert. No, it isn't lucky ;-) I specifically looked for a single invertable function that worked for n=12 and n=34. It doesn't have to work for anything else (well, to work for the binary version as well I had to take something else, still 'simple'. Kahan's example is longer to code.. that is important to me ;-) Thanks for your insights.. always a joy to read. Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
04-15-2020, 12:54 AM
(This post was last modified: 04-15-2020 06:13 PM by Albert Chan.)
For decimal version, we can get precision P with less code
3 1/X 3 × 1 − // -10^(-P), or 0 if binary version (*) this is longer, but will work for binary version too 3 1/X Enter Enter Enter 1 − + + // -10^(-P), or (-2)^(-P) for binary version Example, on python 2.6: >>> x = 1/3. >>> print (x-1+x+x).hex() -0x1.0000000000000p-53 (*) with binary, x = 1/3 has error of ±1/3 ULP 2^P ULP = 1/2 → 3x = 1 ± 1/2^(P+1), which always rounds back to 1 |
04-15-2020, 06:50 AM
Hello Albert
first off, Kahan's 4/3 formula results in 10^-11 and 10^-33, not 10^-12 and 10^-34. And your last 1/3 entry gives 2^-53 for the binary version, while I need 2^-54. If you can beat 0.44 ENTER 1/X 1/X -, let me know ;-) Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
04-15-2020, 01:26 PM
(This post was last modified: 04-15-2020 05:38 PM by Albert Chan.)
(04-15-2020 06:50 AM)Werner Wrote: If you can beat 0.44 ENTER 1/X 1/X -, let me know ;-) Nice find For decimal version, with P decimal precision, above returned (-10)^(-P) Prove: Let x = 0.44 (exactly) // this implied P ≥ 2 y = round(1/x, P-decimals) = c/x, where \(c = 1 + 1.2/(-10)^P\) \(x-1/y = x(1-1/c) = x(c-1)/c = \large {0.528 \over 1.2 + (-10)^P}\) \(\text{ulp_error} = (x-1/y)×10^P = \large {0.528 \over 1.2/10^P + (-1)^P}\) For P = 2, 3, 4, 5, 6, ..., ulp_error ≈ +0.5217, -0.5286, +0.5279, -0.5280, +0.5280 ... limit(|ulp_error|, P=∞) = |0.528/(0±1)| = 0.528 > 0.5 → IROUND(ulp_error) = (-1)^P → round(x-1/y, P-decimals) = (-1)^P ÷ 10^P = (-10)^(-P) P.S. for round-to-nearest, halfway-to-even, above work even with P=1 x - 1/(1/x) → 0.4 - 0.5 = -0.1 = (-10)^(-1) |
