Scaling Prime display on iOS
05-02-2020, 04:14 PM
The display of the Prime iOS app on iPhones does not, by default, use available real estate efficiently. In fact, though the app appears to open full screen, it scales down (on and XS at least) to be smaller than it needs to be. Is there a setting somewhere to fix this or is it a bug?
05-02-2020, 08:31 PM
RE: Scaling Prime display on iOS
(05-02-2020 04:14 PM)Orome Wrote: The display of the Prime iOS app on iPhones does not, by default, use available real estate efficiently. In fact, though the app appears to open full screen, it scales down (on and XS at least) to be smaller than it needs to be. Is there a setting somewhere to fix this or is it a bug? With the HP Prime app shown, slide to the right to reveal the options menu on the left. Choose "Calculator" and then "Hide Title Bar". The app will then scale to fit the entire top and bottom of the screen |
05-02-2020, 08:33 PM
(This post was last modified: 05-02-2020 08:35 PM by Orome.)
(05-02-2020 08:31 PM)Steve Simpkin Wrote: With the HP Prime app shown, slide to the right to reveal the options menu on the left. Choose "Calculator" and then "Hide Title Bar". The app will then scale to fit the entire top and bottom of the screen Awesome! (Actually, it should still be quite a bit bigger, but — good enough.) |
