exporting HP41 fonts in TXT files
05-10-2020, 08:04 PM
(This post was last modified: 05-11-2020 05:30 PM by aurelio.)
Hi all, I've played a little in this weekend with HP IL and the tools to export a program from the calculator to a PC and, back, from a listed program from the PC to the emulator or to the real machine, but the problem for me is to write the special characters, like the "append" one in "TXT" files. How can I do it ? i've searched in the recent or archived topics, but I've not been yet able to find a answer.....
EDIT: is there a way to overcome the problem maybe bypassing the "TXT" file need to complie/decompile? By now I did as follows: _from a real machine+PILBOX (or emulator) to a PC I (PRP)d the program on ILPER or PYILPER _then I imported the printed to a TXT. _I compiled through Ulisse's or Pierre+Leo's tools a RAW file _I got the code with the emulator _I edited the "wrong" lines and I did the same procedure backward. The same job could be done while exporting to the machine... but, I guess, there maybe should be a quick and easyer way... |
