Dichotomy
05-15-2020, 10:18 PM (This post was last modified: 05-16-2020 10:37 AM by pinkman.)
Dichotomy
Just for fun, if you sometimes use dichotomy, a small but useful implementation.
Start the program, enter you start values, then press + or /. Follow the result is on the screen. When you’re done, press Apps, Enter or Esc.
EXPORT DICHO_UP, DICHO_DOWN;
EXPORT DICHO()
 LOCAL BUP, BDWN, K, I, GUESS;
 K := 1;
 I := INPUT({DICHO_UP, DICHO_DOWN},"Dichotomy - Start values",{"Up value    ", "Down value"});
 IF I = 0 THEN
  RETURN 0;
 BUP := DICHO_UP;
 BDWN := DICHO_DOWN;
 IF BUP < BDWN THEN
  BDWN := BDWN - BUP;
  BUP := BUP + BDWN;
  BDWN := BUP - BDWN;
 I := 0;
 WHILE K ≠ 30 AND K > 0 AND K ≠ 4 DO // Keys Enter, Apps or Esc
  RECT();
  I := I+1;
  GUESS := (BUP-BDWN)/2 + BDWN;
  TEXTOUT_P("Press + or - , Enter when done.", 5, 205, 2, RGB(220,80,40));
  TEXTOUT_P("Guess " + STRING(I), 120, 100, 2, RGB(10,200,80));
  TEXTOUT_P(STRING(GUESS), 120, 120, 7);
  TEXTOUT_P(STRING(BDWN), 5, 225, 1, RGB(80,80,80));
  TEXTOUT_P(STRING(BUP), 280, 225, 1, RGB(80,80,80));
  K := WAIT();
  IF K == 45 THEN // minus
   BUP := GUESS;
  ELSE
   IF K == 50 THEN // plus
    BDWN := GUESS;
   ELSE
    I := I-1;
 RETURN GUESS;
Attached File(s) Thumbnail(s)
