LambertW function
05-17-2020, 08:48 AM (This post was last modified: 11-07-2020 09:39 AM by Stevetuc.)
LambertW function
This cas program uses fsolve to calc Lambert fn
#cas
lmb(x):=
fsolve(equal(w*e^w-x,0),w)
#end
Graph from wikipedia
If x <0 lmb(x) returns both principal and negative branch solutions :
lmb(-0.5/e) returns [−2.67834699002,−0.231960952987]
lmb(-1/e) returns −0.999999972234 (negative and principal branch converge at -1 when x=-1/e)
lmb(1) returns 0.56714329041
lmb(2) returns 0.852605502014
11-07-2020, 08:41 AM (This post was last modified: 11-10-2020 08:26 AM by Stevetuc.)
RE: LambertW function
Simplified the code and change to fsolve:
#cas
fsolve(w*e^w=z,w)▶lmb(z);
#end
Result for lmb(-1.78) in home or cas:
8.92180498562ᴇ−2+1.62562367443*i
#cas
fsolve(w*e^w=z,w,0)▶lmb(z);
#end
Edit: add initial guess of 0 to avoid terminal screen in cas. This forces going direct to iterative solver rather than first trying and failing with bisection solver.
Edit: it doesn't fail with Bisectional solver. The cas terminal screen is just for information:
Quote:Solving by bisection with change of variable x=tan(t) and t=-1.57..1.57. Try fsolve(equation,x=guess) for iterative solver or fsolve(equation,x=xmin..xmax) for bisection.
11-07-2020, 11:57 AM (This post was last modified: 11-07-2020 12:37 PM by Albert Chan.)
(11-07-2020 08:41 AM)Stevetuc Wrote:  Edit: add initial guess of 0 to avoid terminal screen in cas.
You might want to mention guess of 0 will iterate for W0(x), i.e. principle branch. (*)
Also, guess 0 is same as guess x, but wasted 1 Newton iteration.
We might as well use guess = x
Newton: w - (w*exp(w) - x) / (w*exp(w) + exp(w))
With guess 0, first iteration of w = 0 - (0 - x) / (0 + 1) = x
(*) Assumed W0 is not complex (x ≥ -1/e), see comment below.
Comment: For fsolve, some randomization of guess is going on.
With complex ON, if we fsolve again and again, we got different solutions.
XCas> fsolve(w*e^w = -1.78, w=0)
0.0892180498562+1.62562367443*i
-1.4781113814-7.66344321151*i
-3.68225172433+70.6337502365*i
-2.07259091944+13.9900896316*i
-2.9207293675-32.8981741284*i
Without randomization, fsolve should not even converge. (w will not flip to complex)
Maybe this is the reason guess randomization kick in ...
11-07-2020, 01:50 PM (This post was last modified: 11-07-2020 01:50 PM by Stevetuc.)
Thanks for pointing that out. I want to retain the secondary branch result when 0 >x ≥ -1/e so I've removed the initial guess on my prime.
