points() in CAS, use different colors?
05-18-2020, 06:37 PM
I noticed that while in CAS mode, I can do things like
point({{1,2},{3,4}})
and it will show a small plot of two points, that I can maximize by touching on it. This is pretty neat.
Can I "hold" the plot (to use Matlab terminology) to add multiple plotting commands to the same graph?
Can I tell the point() command to use different colors for the different points?
05-18-2020, 09:13 PM
RE: points() in CAS, use different colors?
Those plots in CAS view are pretty limited. You can do that in the geometry app, check my answer in your previous post "Add points to plot".
05-18-2020, 09:50 PM
Indeed, as per the other thread, using the Geometry app and Instruction() seems to be the better way to do it.
