Dice roll results
05-24-2020, 04:05 PM
Dice roll results
Hello
I am blocked. Any help welcome.
I want to put in a matrix the possible variations of throwing t dice of c sides.
For 3 dice of 3 sides will be something like (3^3 lines):
[[111][112][113][121][122][123][131][132][133][211]….[333]]
My initial aproach is:
EXPORT TossDice(toss,sides)
LOCAL i,j,k,f,c,p,r;
f:=sides^toss;
c:= toss;
MAKEMAT(f,c)▶r;
p:=1;
FOR i FROM 1 TO f DO
FOR j FROM c+1-p DOWNTO 1 DO
FOR k FROM 1 TO c DO
r[i+k-1,j]:=k;
It is a function similar to rolldie() in R software (prob package).
It does not work and it seems to me that I would have to nest a lot of "for" loops to get it. I do not think is the way to get it.
May be in the forum it has appeared before, if so tell me where.
Thanks very much for your help
Toni
05-24-2020, 06:02 PM
RE: Dice roll results
So you want a deterministic matrix with all the possibilities, not a random distribution, is that it?
05-24-2020, 09:15 PM (This post was last modified: 05-24-2020 09:17 PM by ijabbott.)
You should be able to do it with a couple of loops:
LOCAL i,j,f,p,r;
f := sides^toss;
MAKEMAT(f,toss)▶r;
FOR i FROM 1 to f DO
p := i-1;
FOR j FROM 1 to toss DO
r[i,j] := 1 + p MOD sides;
p := IP(p / sides);
I haven't tested it.
— Ian Abbott
05-24-2020, 11:28 PM
Tongue
  MAKEMAT(IP((I-1)/(sides^(toss-J))) MOD sides+1,sides^toss,toss);
Viga C | TD | FB
05-25-2020, 06:28 PM
Thanks very very much to all.
Beautiful, simple, just much better than what I have finally done with a big mess:
EXPORT RollDi(toss,dice)
LOCAL v,v1,j,k,d,f;
LOCAL t,p,p1,r,r1,l;
d:=dice;
v:=MAKEMAT(J+K,1,d);
v1:=MAKEMAT(0,1,d);
t:=toss;
f:=d^t;
r:=MAKEMAT(0,t,f);
r1:=MAKEMAT(0,1,f);
p:=1;
FOR k FROM 1 TO t DO //loop de t columnas
WHILE p<f DO //rellena cada columna
FOR j FROM 1 TO d DO
MAKEMAT(v[1,j],1,d^(k-1))▶v1;
l:=length(transpose(v1));
CAS.REPLACE(r1,p,v1);
p:=p+l
p:=1;
CAS.REPLACE(r,{t+1-k,1},r1);
r1:=MAKEMAT(0,1,f);
RETURN transpose(r);
It works, at least for low numbers.
Just for future nights with no sleeping, could you tell me how to jump from one point to another while debugging a program? Just to do a complete "loop" for example.
Bye
05-25-2020, 10:04 PM
Just insert this in your program code where you need to (re)start debugging :
DEBUG();
05-25-2020, 10:08 PM (This post was last modified: 05-25-2020 10:09 PM by pinkman.)
To be more precise: the DEBUG instruction launches the debugger and halt at the point your program execution is. This acts like a breakpoint.
If you need conditional breakpoint, simply insert this instruction in a conditional statement : IF .. THEN DEBUG();
Thibault
05-26-2020, 11:05 PM
Thanks very much.
Easy and very helpful
05-28-2020, 07:03 AM
Hello, just to add extra information, if you want to check your results there is this web page:
https://anydice.com/
There, you can play with any number of n-sided dice. Very interesting!, at least for me.
Bye!
05-30-2020, 03:31 PM
Hello
Following with the probability I am using a book called:
"Introduction to Pobability and Statistics Using R" by Jay Kerns.
It is full of examples not very complicated. So my intention when I have free time is to practice with the Prime to do the same functions as described in it.
I have already written some with your help. I try to attach the initial program, is my first time so I hope I do it properly.
Thanks
Toni
Attached File(s)
.hpprgm  RollDi.hpprgm (Size: 6.68 KB / Downloads: 3)
