EXIT program from MENU softkey?
05-29-2020, 05:17 PM
Is there a way to EXIT a program from the softmenu? The EXIT key works but I would like to have a key in the MENU via softkey to exit the program. I have searched the Examples and Techniques manual and haven't found anything that indicates I can do this.
I thought there may be a way to Simulate a key push of the EXIT button, but I can't get that working.
I am working from a DM42 if that makes a difference.
HP48GX, HP42s and DM42.
05-29-2020, 06:29 PM
RE: EXIT program from MENU softkey?
If you want to stop a running program with a menu key, the answer is no.
If you want to EXIT the program when it is waiting for you to push a menu key, yes: have the key perform EXITALL and RTN.
EXITALL unfortunately is only found in the FCN menu; I keep it permanently assigned to one of the CST menu keys
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
05-29-2020, 07:46 PM
Thanks Werner. That is a good idea. I just moved GTO and EXITALL to my Custom menu. Any other's you may believe worthwhile to consider?
05-29-2020, 08:53 PM
Why did you put GTO there? it's shift-XEQ.
Werner
05-29-2020, 09:10 PM
(05-29-2020 08:53 PM)Werner Wrote:  Why did you put GTO there? it's shift-XEQ.
Werner
Because I’m still not use to the layout and looked over it. Thanks. Removed.
05-30-2020, 05:29 AM
Other ‘candidates’ for the CST menu:
R^
X<>
Werner
05-30-2020, 06:07 AM
I always add %CH
06-13-2020, 10:52 PM
(05-30-2020 06:07 AM)pinkman Wrote:  I always add %CH
Thank you Pinkman. You are Werner sped up my adoption of the 42 platform.
