Problems of HP prime with triple integrals?
05-31-2020, 07:41 AM
I tried to compute the following triple integral:
integral(integral(integral(e^(-x²+y²/2+1/z))dz)dy)dx
with the following limits: x: 0.,1.; y:0.,2.; z:1.,4.
Screenshot of the HP prime Pro software is attached.
I tried it with the HP Prime Pro PC software and with a HP prime G2. None delivered a solution within half an hour.
The TI-nspire CX II-T CAS came to the solution 17.147920 within 1 or 2 seconds. Even my old TI-89 titanium showed the same solution within 10 seconds.
Does the HP prime have problems with triple integrals or is there something I am doing wrong?
Thank you very much and best regards
Raimund Wildner
Attached File(s)
.docx  triple_integral.docx (Size: 284.18 KB / Downloads: 37)
05-31-2020, 09:38 AM
RE: Problems of HP prime with triple integrals?
Any calculator will have trouble with triple integrals that don't factorise into a product of single-variable integrals. To evaluate such an integral numerically to a high degree of precision requires of the order of \(N^3\) points, compared with \(N\) points for similar precision for a single-variable integral.
Your integral factorises, so calculators that spot this can evaluate it rapidly. The Prime doesn't appear to check for this, so it evaluates the integral the long way.
I would guess that for multiple integrals that don't factorise the Prime and TI NSpire would be comparable, with the Titanium way behind!
Having said that, I am surprised that the Prime didn't finish at all. Perhaps there is a problem.
Nigel (UK)
05-31-2020, 10:54 AM
Strange. If I change variables to \(u=1/z\), then with exact mode ticked and approximate evaluation I get the correct answer to the triple integral at once, after a couple of messages.
With exact mode not ticked I get a message about using Romberg, then the calculator carries on calculating until interrupted.
With \(1/z\) in the exponent I can't get an answer to the triple integral at all, although the equivalent single integral evaluates with no problem.
Something's not right!
Nigel (UK)
05-31-2020, 01:21 PM
(05-31-2020 10:54 AM)Nigel (UK) Wrote:  Strange. If I change variables to u=1/z, then with exact mode ticked and approximate evaluation I get the correct answer to the triple integral at once, after a couple of messages.
With u=1/z, integral is trivial to evaluate, with integration by parts
\(\large \int e^{1\over z}\;dz
= \int e^u\;d({1\over u})
= {e^u \over u} - \int {1 \over u}\;d(e^u)
= {e^u \over u} - Ei(u)
05-31-2020, 04:04 PM
The TI-Nspire CX 2 (non CAS) also manages to report the correct answer...
[/u]
05-31-2020, 04:10 PM
(05-31-2020 09:38 AM)Nigel (UK) Wrote:  Having said that, I am surprised that the Prime didn't finish at all. Perhaps there is a problem.
Hi Nigel,
thanks a lot for your answer. HP prime really seems to have a problem here. I tried it once more and after about an hour there came a message like "A problem occured to HP Prime and it will switch off in 3 seconds". Then it switched off. If switched on again everything is normal, no message. So normally you will not see it.
So I think I have to program it step by step, e.g. using Gauss' or Romberg's method.
Best
Raimund
01-07-2021, 07:23 PM
It's easier to compute the product of 3 integrals
int(exp(-x^2),x,0,1)*int(exp(y^2/2),y,0,2)*int(exp(1/z),z,1,4.0)
