Volume of a bead with square hole- Program approach?
06-11-2020, 06:53 PM
(This post was last modified: 06-16-2020 04:16 PM by Albert Chan.)
Post: #21
RE: Volume of a bead with square hole- Program approach?
Here is a simplied version of Werner's code, assumed diameter = 1
I like dimensionless version because you can get a sense of results. Example, with diameter of 1, sphere volume = Pi/6 ≈ 0.523598775598 ≈ ½ You can sense how big the hole is ... Also, A, B is limited to inside a unit circle. Code: 00 { 83-Byte Prgm } Example, to get sphere - hole, diameter = 20, hole = 2x2 Solve with A=0.1, B=0.1, we have hole = 0.00996658845699, about 2% of sphere Pi/6 - V = 0.513632187141 Scale up by D^3 => sphere - hole = 0.513632187141 * 20^3 = 4109.05749713 Update: Perhaps we should compare volume against maximum possible volume Solve with sphere - 4 caps, or simply solve with A = B = √(0.5), we get V(max) ≈ 0.402001836518 So, above hole ≈ 2½ % of maximum possible volume. |
06-16-2020, 12:35 PM
(This post was last modified: 11-05-2023 03:59 PM by Albert Chan.)
Post: #22
(06-11-2020 06:53 PM)Albert Chan Wrote: Solve with A=0.1, B=0.1, we have hole = 0.00996658845699, about 2% of sphere For small square hole, we can estimate with simple formula For unit diameter (d=1), with square hole, b=a XCas> k := sqrt(1-2*b*b) XCas> hv2 := b*b*k/3 - atan(b*b/k)/3 + b*(1-b*b/3)*atan(b/k) XCas> hv2(b = 0.1) // just to confirm square hole formula → 0.00996658845699 XCas> taylor(hv2,b,10) → b^2 - b^4/3 + -7*b^6/90 + -3*b^8/70 + -83*b^10/2520 + b^12*order_size(b) Since taylor series all have even powers, let dimensionless x = b^2 XCas> pade(x - x^2/3 - 7*x^3/90, x, 3,3) → (17*x^2-30*x)/(7*x-30) XCas> r(x) := x*(17*x-30)/(7*x-30) XCas> r(0.1^2) // rough estimate for small 0.1×0.1 hole → 0.00996658870698 |
11-05-2023, 04:16 PM
Post: #23
(06-16-2020 12:35 PM)Albert Chan Wrote: For unit diameter (d=1), with square hole, b=a hv2 ≈ b^2 * √(1 - (2b^2)/3) = b^2 * √(1 - (1-k^2)/3) Remove b=a requirement: hv2 ≈ a*b * √(1 - (a^2+b^2)/3) Remove d=1 requirement: hv2 ≈ a*b * √(d^2 - (a^2+b^2)/3) It is not as accurate hv2 pade approximation, but likely good enough Previous example, d = 1, a = b = 0.1 lua> d, a, b = 1, 0.1, 0.1 lua> a*b * sqrt(d*d - (a*a+b*b)/3) 0.009966610925150703 Hole volume with 5 good digits, over-estimated. Last term (estimated average height) is equivalent to RMS(d, d, sqrt(d*d-a*a-b*b)) Repalce RMS with arithemetic mean, we get the under-estimated hole volume. lua> a*b * (2*d + sqrt(d*d-a*a-b*b)) / 3 0.00996649831220389 This is not as good as RMS version, does not reduce computation, thus not recommended. |
11-05-2023, 04:28 PM
Post: #24
To be clear, my son's integral solves for the volume left behind in the sphere after the hole has been removed. I have listed three volumes below. I wasn't sure if I was clear on this.
d = 12 a = 2 b = 2 Volume of sphere solid = 904.779 Volume of sphere with hole removed = 857.0638 Volume of hole removed = 47.715 Thoughts? HP48GX, HP42s and DM42. |
11-05-2023, 05:15 PM
(This post was last modified: 11-05-2023 09:41 PM by Albert Chan.)
Post: #25
(11-05-2023 04:28 PM)DM48 Wrote: d = 12 sphere volume = pi*d^3/6, looks good --> we check removed hole only. This is a good test of my recent estimate, lo < (average height) < hi lua> d, a, b = 12, 2, 2 lua> lo = (2*d + sqrt(d*d-a*a-b*b))/3 lua> hi = sqrt(d*d - (a*a+b*b)/3) lua> a*b*lo, a*b*hi 47.5492050529208 47.55347866700536 Your hole volume is outside this range. sphere (with hole) volume formula is incorrect. Perhaps you can show steps to derive the formula? Here is Derive6 calculated hole volume #1: r := 6 #2: a := 2 #3: b := 2 #4: 8·∫(∫(√(r·r - x·x - y·y), x, 0, a/2), y, 0, b/2) Shift-Enter (or click [✔≈]) → 47.55262983 Comment: 8 = 2^3, we could scale-up all 3 dimensions, to remove factor 8 #5 d := 2*r #6: ∫(∫(√(d·d - x·x - y·y), x, 0, a), y, 0, b) → 47.55262983 |
11-05-2023, 08:01 PM
(This post was last modified: 11-05-2023 09:53 PM by DM48.)
Post: #26
This gave us a reason to finally get somewhat serious with 3D AutoCAD. 857.22 is correct. My son's formula is off a hair. He is going to work on the derivation of this formula for anyone to scrutinize possibly explain why it is off. HP48GX, HP42s and DM42. |
11-05-2023, 08:27 PM
Post: #27
(11-05-2023 08:01 PM)DM48 Wrote: This gave us a reason to finally get somewhat serious with 3D AutoCAD. 857.22 is correct. My son's formula is off a hair. He is going to work on the derivation of this formula for anyone to scrutinize possibly explain why it is off. I'd say you can bring down the size of that image to about 10-15% of it's current size, it's silly the way it is now. --Bob Prosperi |
11-05-2023, 09:52 PM
Post: #28
(11-05-2023 08:27 PM)rprosperi Wrote:(11-05-2023 08:01 PM)DM48 Wrote: This gave us a reason to finally get somewhat serious with 3D AutoCAD. 857.22 is correct. My son's formula is off a hair. He is going to work on the derivation of this formula for anyone to scrutinize possibly explain why it is off. I have tried to resize it with img=##x## but it does not display. HP48GX, HP42s and DM42. |
11-06-2023, 02:47 AM
Post: #29
(11-05-2023 09:52 PM)DM48 Wrote: I have tried to resize it with img=##x## but it does not display. Not sure what's going on, as Joe said maybe there are limits. I wasn't suggesting you make it unusable, it just looked a bit silly the way it was. Feel free to restore it if that's the only way it's useful to see the details. --Bob Prosperi |
11-07-2023, 04:07 PM
(This post was last modified: 11-07-2023 07:52 PM by Albert Chan.)
Post: #30
(11-05-2023 04:16 PM)Albert Chan Wrote:(06-16-2020 12:35 PM)Albert Chan Wrote: For unit diameter (d=1), with square hole, b=a To show hole volume is over-estimated, we check sign of errors lua> taylor(hv2 - b^2 * √(1 - (2b^2)/3), b, 10) - b^6/45 - 23*b^8/945 - 143*b^10/5670 + b^12*order_size(b) Negative under-estimated error → RMS formula over-estimated hole volume. Quote:Last term (estimated average height) is equivalent to RMS(d, d, sqrt(d*d-a*a-b*b)) height of rect cap (both of them), h = 1-k // 1 is diameter, k is corner height mean([1,1,k]) = 1 - h/3 = (1-h) + 2/3*h MEAN formula under-estimated hole volume, if rect cap mean height > 2/3*h XCas> ratio := (hv2/(b*b)-k) / (1-k) XCas> taylor(ratio, b, 8, polynom) 2/3 + 4/45*b^2 + 5/63*b^4 + 23/252*b^6 + 1997/16632*b^8 Small hole, h and b^2 about the same size: k = 1-h = sqrt(1-2*b^2) ≈ 1-b^2 Ratio converge faster (smaller coefficients), if we use variable h. XCas> taylor(ratio(b=sqrt((1-(1-h)^2)/2)), h, 6, polynom) 2/3 + 4/45*h + 11/315*h^2 + 1/84*h^3 + 25/8316*h^4 Compare mean height ratio with spherical cap. V = pi*h/6 * (3*a^2 + h^2) A = pi*a^2 ratio = V/A/h = 1/2 + (h/a)^2/6 > 1/2 |
11-07-2023, 10:25 PM
Post: #31
Code: function hv2(d,a,b) -- sphere, rectanglar hole removed volume Although estimation formula assumed square hole, inequality work with rectangular hole too. For estimate, hv2_m2(d,a,b) is recommended: cheaper to compute, better accuracy. |
11-08-2023, 02:11 AM
(This post was last modified: 11-08-2023 02:14 AM by DM48.)
Post: #32
Link to derivation of formula.
\( \int_{0}^{a} \int_{0}^{\sqrt{d^2-y^2-b^2}}\sqrt{d^2-y^2-x^2}-b\text{ }dx\text{ }dy\text{ }+\int_{a}^{d}\int_{0}^{\sqrt{d^2-y^2}}\sqrt{d^2-y^2-x^2}\text{ }dx\text{ }dy \) In[842]:= Clear[a, b, q, r, x] d = 12 a = 2 b = 2 q = NIntegrate[ Integrate[ Sqrt[d^2 - y^2 - x^2] - b, {x, 0, Sqrt[d^2 - y^2 - b^2]}], {y, 0, a}] r = NIntegrate[ Integrate[Sqrt[d^2 - y^2 - x^2], {x, 0, Sqrt[d^2 - y^2]}], {y, a, d}] q + r Out[848]= 857.2260543948448 a=4 b=2 d=12 Out[849]=811.0424359298954 HP48GX, HP42s and DM42. |
11-08-2023, 04:58 PM
(This post was last modified: 11-08-2023 10:29 PM by Albert Chan.)
Post: #33
Hi, DM48
Nice to know there is another way to get volume: sphere - hole = (x-strip - hole) + (2 spherical caps) Since we have direct formula for spherical cap, 2nd integral can be skipped 2 caps = 2 * pi/3*h^2*(3r-h) = pi/12*(2h)^2*(3d-2h) = pi/12*(d-a)^2*(2d+a) 10 DEF FNH(X) @ N=N+1 @ FNH=SQRT(H-X*X) @ END DEF 20 DEF FNZ(Y) @ H=D*D-Y*Y @ FNZ=INTEGRAL(0,FNH(B),P,FNH(IVAR)-B) @ END DEF 30 INPUT "D,A,B = ";D,A,B @ N=0 @ P=1E-5 40 I1=INTEGRAL(0,A,P,FNZ(IVAR)) @ I2=PI/12*(D-A)^2*(2*D+A) 50 DISP I1;"+";I2;"=";I1+I2,N @ GOTO 30 >run D,A,B = 12,2,2 176.547653773 + 680.678408277 = 857.22606205 960 D,A,B = 12,2,10 17.2338339713 + 680.678408277 = 697.912242248 992 D,A,B = 12,10,2 662.307552043 + 35.6047167408 = 697.912268784 1888 Numerically, thinner, less curvy strip (A ≤ B) converge better. For comparison, below patch directly get (-hole) + sphere >20 DEF FNX(Y) @ H=D*D-Y*Y @ FNX=INTEGRAL(0,B,P,FNH(IVAR)) @ END DEF >40 I1=-INTEGRAL(0,A,P,FNX(IVAR)) @ I2=PI/6*D*D*D >run D,A,B = 12,2,2 -47.552634005 + 904.778684234 = 857.226050229 225 D,A,B = 12,2,10 -206.866458199 + 904.778684234 = 697.912226035 465 D,A,B = 12,10,2 -206.866453454 + 904.778684234 = 697.91223078 465 |
11-09-2023, 11:18 PM
Post: #34
11-10-2023, 01:52 AM
Post: #35
Hi, DM48
Double integral reduced to single. Nice! I simplified a bit, using Arc SOHCAHTOA method 10 DEF FNZ(Y) @ N=N+1 @ Y=D*D-Y*Y @ FNZ=Y*ACOS(B/SQR(Y)) @ END DEF 20 INPUT "D,A,B = ";D,A,B @ N=0 @ P=1E-5 30 I1=INTEGRAL(0,A,P,FNZ(IVAR))/2 @ C=SQR(D*D-A*A-B*B) 40 I2=PI/12*(D-A)^2*(2*D+A) - B/4*(A*C+(D*D-B*B)*ATAN(A/C)) 50 DISP I1;"+";I2;"=";I1+I2,N @ GOTO 20 >run D,A,B = 12,2,2 200.09879005 + 657.127264322 = 857.226054372 15 D,A,B = 12,2,10 82.547121343 + 615.365121066 = 697.912242409 31 D,A,B = 12,10,2 764.410058495 + -66.4978178412 = 697.912240654 31 Below is direct formula for I1 (c is corner height, see code) >a*(3*d^2-a^2)*pi/12 - a*b*c/12 858.633041958 >res - b*(3*d^2+b^2)*atan(a/c)/12 785.468340817 >res - a*(3*d^2-a^2)*atan(b/c)/6 615.99486321 >res + d^3*atan(a*b/(c*d))/3 764.410059992 |
