HP-48SX ON Key
06-08-2020, 11:52 PM
HP-48SX ON Key
The ON key in my HP-48SX stopped working. I cannot turn the calculator on. I understand this is an age-related problem. Is this a way to repair this? Does repair involve opening the calculator? Thanks in advance. Juan |
06-09-2020, 11:15 AM
RE: HP-48SX ON Key
If pushing gently under the display causes the "on" button to work it is probably the foam strip under the ribbon connector. From what I have read a common issue for many models. If you are lucky you can just use the "pressure method" to turn it off/on (until it stops all together).
A friend had this issue with his 48s and while daunting it can be done. IIRC there are a few people who can repair it here if it is the foam strip. There are a bunch of threads here on it too - taking it apart and reassembly. The 48g is the same procedure so check those threads too. -B |
