Harmonic numbers on the HP 50g
06-02-2014, 03:11 PM
I recently discovered that the HP 50g function Psi (in MTH NXT SPECIAL) delivers the nth harmonic number:
Hn = Psi(n + 1) – Psi(1) [and that, by the way, –Psi(1) = 0.577215664902, the Euler constant]. This observation, together with the numerical SOLVE command, allows quick disposal of (say) the problem of finding the smallest integer k for which Hk > 7.6, and it might more generally be useful in mathematics teaching. |
06-02-2014, 10:07 PM
RE: Harmonic numbers on the HP 50g
I implemented the digamma function for the 34S but it didn't make it in
![]() But where to stop including useful functions.... - Pauli |
06-03-2014, 05:41 AM
(This post was last modified: 06-03-2014 05:48 AM by Ángel Martin.)
(06-02-2014 10:07 PM)Paul Dale Wrote: I implemented the digamma function for the 34S but it didn't make it in Digamma (Psi) is also useful to obtain the inverse Gamma using Newton's method, there was a thread in the old forum about that but can't find it now. edit: here's the link The SandMath has both the harmonic number and Psi functions - the accuracy limited to 10 digits of course. Cheers, 'AM |
