How to rearrange app icons
06-15-2020, 10:51 AM
(This post was last modified: 06-15-2020 11:15 AM by MrMcChicken.)
Hello, i remember beeing able to rearrange the app icons by a long press/touch and then moving them. For some reason i cannot get it to work now. Was this disabled in a firmware update or do I have to enable a special setting?
Thanks EDIT: So I reflashed a backup, it worked with that. After that I flashed the new version again, which works now too. This is a little weird for me. The touchscreen worked in all cases, I am using the G1 version. |
06-15-2020, 02:02 PM
RE: How to rearrange app icons
It occurs to me that the long touch failed, it happens from time to time, I still have not identified the cause. On+Symb fixes touch issue
Viga C | TD | FB |
06-18-2020, 08:09 AM
RE: How to rearrange app icons | |||
