19C - printer - 12Ohm OK - voltage pulses OK - but not printing
07-03-2020, 12:35 PM
(This post was last modified: 07-03-2020 12:48 PM by RolfSchlagenhaft.)
glad that I found this forum. Maybe there is somebody who has an idea how to proceed with my problem. I did a search before and didn't find a similar problem described or solved. So bear with me, that my first post is a question. Situation: I have a 19C. Calculator, display, power supply, printer head motor and paper transport work fine. Yet, no symbols show up on the paper. What I did so far:
Apropos paper: I'm using two kinds of paper: One from HP-97 which I cut to the correct width for the 19C, which would print in blue. And a third party thermal paper with correct width, which would print in black. I have no idea what next analysis step I shall take. I don't want to replace the dot driver transistor arrays just based on speculation that they could be the root cause. Any hint would be much appreciated. Rolf HP-33E successfully restored HP-19C calculating but not printing HP-97 pending restoration |
07-03-2020, 12:47 PM
RE: 19C - printer - 12Ohm OK - voltage pulses OK - but not printing
Additional info:
The mechanics of the print head look OK to me. The paper is properly pressed against the moving print head. So, if the dots create heat, I'd expect something on paper. Rolf HP-33E successfully restored HP-19C calculating but not printing HP-97 pending restoration |
07-03-2020, 09:08 PM
(07-03-2020 12:47 PM)RolfSchlagenhaft Wrote: Additional info:Have you applied some heat to your paper(s) by some other means? Is it possible you've got old/non-functioning paper? Can you measure the (average) current to a dot with your voltmeter? |
07-03-2020, 10:18 PM
(07-03-2020 12:35 PM)RolfSchlagenhaft Wrote: Situation:I have a 19C. Calculator, display, power supply, printer head motor and paper transport work fine. Yet, no symbols show up on the paper. have a look at this document. Taschenrechnersammlung.pdf. The second part (in English) contains lots of info on fixing HP calcs in general and HP-19C in particular. Best Vassilis http://www.series80.org |
07-04-2020, 01:50 AM
(07-03-2020 10:18 PM)vassilisprevelakis Wrote: The second part (in English) contains lots of info on fixing HP calcs in general and HP-19C in particular. Yes, seconded! Bernhard has a great deal of information there. (The 19C he repaired had a similar printer fault that turned out to be the potentiometer that controls the print darkness. You might want to check that first.) |
07-05-2020, 04:07 PM
(07-03-2020 09:08 PM)Dave Shaffer Wrote:Thanks fo the proposals!(07-03-2020 12:47 PM)RolfSchlagenhaft Wrote: Additional info:Have you applied some heat to your paper(s) by some other means? Is it possible you've got old/non-functioning paper? The paper works. I confirmed it by burning it and also by writing with a soldering iron on it. I reacts in same way as I was used to it in past. I need to check the manual of my multimeter whether it allows averaging. Good idea, thanks! HP-33E successfully restored HP-19C calculating but not printing HP-97 pending restoration |
