67 ISZ
07-14-2020, 06:30 AM
67 ISZ
Hi all,
Just playing around with the 67 emulator. Does the ISZ function actually get a chance to skip on zero or is in only good for a counter? Example: I = 9.999999999 E99 then do ISZ I doesn't wrap around to 0 on overflow so still equals 9.9999999999 E99 and therefore a skip never executes. cheers Tony |
07-14-2020, 06:59 AM
RE: 67 ISZ
9.999999999 E99 + 1 doesn't overflow of course.
Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
07-14-2020, 07:46 AM
RE: 67 ISZ
Are you ignoring negative values of I?
— Ian Abbott |
07-14-2020, 10:05 AM
RE: 67 ISZ | |||
07-14-2020, 12:46 PM
RE: 67 ISZ
I think the 67's ISZ/DSZ also have interesting behaviour for fractional values. From memory skipping if -1 < I < 1.
ISZ/DSZ were not present on the proposed 67+. Pauli |
07-14-2020, 01:48 PM
RE: 67 ISZ
(07-14-2020 12:46 PM)Paul Dale Wrote: I think the 67's ISZ/DSZ also have interesting behaviour for fractional values. From memory skipping if -1 < I < 1. The manual states "For test purposes, numbers between but not including -1 and +1 are the same as zero." Paul. |
07-15-2020, 12:02 AM
RE: 67 ISZ
(07-14-2020 01:48 PM)Paul Berger (Canada) Wrote:(07-14-2020 12:46 PM)Paul Dale Wrote: I think the 67's ISZ/DSZ also have interesting behaviour for fractional values. From memory skipping if -1 < I < 1. Only the integer part of the number is used, so 0.99 or -0.99 = 0 cheers Tony |
07-15-2020, 04:52 AM
RE: 67 ISZ
Exactly, this is quite different to ISG and DSE.
The 34S supports all flavours of course. Pauli |
07-15-2020, 08:50 AM
RE: 67 ISZ
(07-15-2020 04:52 AM)Paul Dale Wrote: Exactly, this is quite different to ISG and DSE. I may be missing something but, I wonder why the comparison is between a 5 digit number and a 3 digit number, ie, is 12345 > 123. I would have thought it would seem more logical to have used two 3 digit numbers. cheers Tony |
07-15-2020, 10:36 AM
RE: 67 ISZ
The larger range is useful for DSE.
For ISG, it seems less so. Pauli |
