Micro$oft SMALLBASIC
08-15-2020, 03:34 PM
Hi.
Important for teachers.
I am starting to use Micro$oft SMALLBASIC to teach algorithmic logic to beginning students.
SMALLBASIC has three independent windows
Two-way console or text input and output window
Graph window
Graph window by turtle interface
Two versions, one for desktop execution and one online
SB can detect various events for the mouse and keyboard, and even with external hardware like arduino and others.
SB https://smallbasic-publicwebsite.azurewebsites.net/
an example of Game written in SB
PHP Code:
GraphicsWindow.KeyDown HandleKey
GraphicsWindow
.BackgroundColor GraphicsWindow.GetColorFromRGB253252251 )
While
"True"
BOXES 4      ' number of boxes per piece
  BWIDTH = 25    '
box width in pixels
  XOFFSET
40   ' Screen X offset in pixels of where the board starts
  YOFFSET = 40   '
Screen Y offset in pixels of where the board starts
  CWIDTH
10    ' Canvas Width, in number of boxes
  CHEIGHT = 20   '
Canvas Heightin number of boxes.
STARTDELAY 800
  ENDDELAY
175
  PREVIEW_xpos
13
  PREVIEW_ypos
2
  GraphicsWindow
.Clear()
GraphicsWindow.Title "Small Basic Tetris"
GraphicsWindow.Height 580
  GraphicsWindow
.Width 700
  GraphicsWindow
.Show()
SetupTemplates()
SetupCanvas()
MainLoop()
GraphicsWindow.ShowMessage"Game Over""Small Basic Tetris" )
EndWhile
Sub MainLoop
  template
Text.Append("template"Math.GetRandomNumber(7))
CreatePiece() ' in: template ret: h
  nextPiece = h
  end = 0
  sessionDelay = STARTDELAY
  While end = 0
    If sessionDelay > ENDDELAY Then
      sessionDelay = sessionDelay - 1
    EndIf
    delay = sessionDelay
    thisPiece = nextPiece
    template = Text.Append("template", Math.GetRandomNumber(7))
    CreatePiece() '
intemplate reth
    nextPiece
h
    DrawPreviewPiece
thisPiece
    ypos
0
    done
0
    xpos
' always drop from column 3
    CheckStop() '
inyposxposh retdone
If done 1 Then
      ypos
ypos 1
      MovePiece
()  'in: ypos, xpos, h
      end = 1
    EndIf
    yposdelta = 0
    While done = 0 Or yposdelta > 0
      MovePiece()  '
inyposxposh
' Delay, but break if the delay get set to 0 if the piece gets dropped
      delayIndex = delay
      While delayIndex > 0 And delay > 0
        Program.Delay(10)
        delayIndex = delayIndex - 10
      EndWhile
      If yposdelta > 0 Then
        yposdelta = yposdelta - 1  '
used to create freespinwhen the piece is rotated
Else
ypos ypos 1            ' otherwise, move the piece down.
      EndIf
Check if the piece should stop.
CheckStop() ' in: ypos, xpos, h ret: done
    EndWhile
  EndWhile
EndSub
Sub HandleKey
Stop game
If GraphicsWindow.LastKey "Escape" Then
    Program
.End()
  EndIf
' Move piece left
  If GraphicsWindow.LastKey = "Left" Then
    moveDirection = -1
    ValidateMove()  '
inyposxposhmoveDirection retinvalidMove or -or if move is invalidotherwise 0
If invalidMove 0 Then
      xpos
xpos moveDirection
EndIf
MovePiece()  'in: ypos, xpos, h
  EndIf
Move piece right
If GraphicsWindow.LastKey "Right" Then
    moveDirection
1
    ValidateMove
()  ' in: ypos, xpos, h, moveDirection ret: invalidMove = 1 or -1 or 2 if move is invalid, otherwise 0
    If invalidMove = 0 Then
      xpos = xpos + moveDirection
    EndIf
    MovePiece()  '
inyposxposh
EndIf
' Move piece down
  If GraphicsWindow.LastKey = "Down" or GraphicsWindow.LastKey = "Space" Then
    delay = 0
  EndIf
Rotate piece
If GraphicsWindow.LastKey "Z" Then
    basetemplate
= Array.GetValue(h, -1)  ' Array.GetValue(h, -1) = the template name
    template = "temptemplate"
    rotation = "CW"
    CopyPiece()  '
in basetemplatetemplaterotation
Array.SetValue(h, -1template' Array.GetValue(h, -1) = the template name
    moveDirection = 0
    ValidateMove()  '
' See if it can be moved so that it will rotate.
    xposbk = xpos
    yposdelta = 0
    While yposdelta = 0 And Math.Abs(xposbk - xpos) < 3 '
move up to 3 times only
' if the rotation move worked, copy the temp to "rotatedtemplate" and use that from now on
        basetemplate = template
        template = "rotatedtemplate"
        Array.SetValue(h, -1, template) '
        rotation
"COPY"
CopyPiece()  'in basetemplate, template, rotation
        yposdelta = 1 '
Don't move down if we rotate
        MovePiece()  '
inyposxposh
ElseIf invalidMove 2 Then
' Don't support shifting piece when hitting another piece to the right or left.
xpos 99 ' exit the loop
      Else
if the rotated piece can't be placed, move it left or right and try again.
        xpos = xpos - invalidMove
        ValidateMove()  '
EndIf
    EndWhile
    If
invalidMove <> 0 Then
      xpos
xposbk
Array.SetValue(h, -1basetemplate' Array.GetValue(h, -1) = the template name
      template = ""
    EndIf
  EndIf
EndSub
Sub DrawPreviewPiece
  xpos = PREVIEW_xpos
  ypos = PREVIEW_ypos
  h = nextPiece
  XOFFSETBK = XOFFSET
  YOFFSETBK = YOFFSET
  XOFFSET = XOFFSET + Array.GetValue(Array.GetValue(h, -1), "pviewx") '
  YOFFSET
YOFFSET + Array.GetValue(Array.GetValue(h, -1), "pviewy"' Array.GetValue(h, -1) = the template name
  MovePiece()  '
inyposxposh
  XOFFSET
XOFFSETBK
  YOFFSET
YOFFSETBK
EndSub
' creates template that's a rotated basetemplate
Sub CopyPiece
  L = Array.GetValue(basetemplate, "dim")
  If rotation = "CW" Then
    For i = 0 to BOXES - 1 '
x' = y y' x
      v
= Array.GetValue(basetemplatei)
'x = Math.Floor(v/10)
Math.Remainder(v10)
' new x and y
      x = (Math.Remainder(v, 10))
      y = (L - 1 - Math.Floor(v/10))
      Array.SetValue(template, i, x * 10 + y)
    EndFor
Count-Cockwise is not currently used
ElseIf rotation "CCW" Then
For 0 to BOXES ' x' y y' = x
      v = Array.GetValue(basetemplate, i)
Math.Floor(v/10)
'y = Math.Remainder(v, 10)
new and y
      x
= (Math.Remainder(v10))
Math.Floor(v/10)
      Array.
SetValue(templatei10 y)
    EndFor
  ElseIf
rotation "COPY" Then
For 0 to BOXES 1
Array.SetValue(templatei, Array.GetValue(basetemplatei))
    EndFor
  Else
GraphicsWindow.ShowMessage("invalid parameter""Error")
Program.End()
  EndIf
' Copy the remain properties from basetemplate to template.
  Array.SetValue(template, "color", Array.GetValue(basetemplate, "color"))
  Array.SetValue(template, "dim", Array.GetValue(basetemplate, "dim"))
  Array.SetValue(template, "pviewx", Array.GetValue(basetemplate, "pviewx"))
  Array.SetValue(template, "pviewy", Array.GetValue(basetemplate, "pviewy"))
EndSub
Sub CreatePiece '
intemplate reth
' Create a new handle, representing an arrayName, that will represent the piece
  hcount = hcount + 1
  h = Text.Append("piece", hcount)
  GraphicsWindow
.PenWidth 1
  GraphicsWindow
.PenColor "Black"
GraphicsWindow.BrushColor = Array.GetValue(template"color")
  For
0 to BOXES 1
    s
Shapes.AddRectangle(BWIDTHBWIDTH)
Shapes.Move(s, -BWIDTH, -BWIDTH' move off screen
    Array.SetValue(h, i, s)
  EndFor
EndSub
Sub MovePiece '
inyposxposhypos/xpos is 0-19representing the top/left box coordinate of the piece on the canvash returned by CreatePiece
For 0 to BOXES 1
    v
= Array.GetValue(Array.GetValue(h, -1), i)  ' Array.GetValue(h, -1) = the template name
Array.GetValue(hi) = box for piece h.
' xpos/ypos = are topleft of shape. x/y is the box offset within the shape.
    Shapes.Move(Array.GetValue(h, i), XOFFSET + xpos * BWIDTH + x * BWIDTH, YOFFSET + ypos * BWIDTH + y * BWIDTH)
  EndFor
EndSub
Sub ValidateMove '
  i
0
  invalidMove
0
While BOXES
    v
Math.Floor(v/10)
Math.Remainder(v10)
    If (
xpos moveDirection) < 0 Then
      invalidMove
= -1
      i
BOXES ' force getting out of the loop
    EndIf
    If (x + xpos + moveDirection) >= CWIDTH Then
      invalidMove = 1
      i = BOXES '
EndIf
    If Array.
GetValue("c", (xpos moveDirection) + (ypos) * CWIDTH) <> "." Then
      invalidMove
2
      i
    EndIf
    i = i + 1
  EndWhile
EndSub
Sub CheckStop '
inyposxposh retdone
  done
0
  i
0
While BOXES
    v
Math.Floor(v/10)
Math.Remainder(v10)
    If
ypos CHEIGHT Or Array.GetValue("c", (xpos) + (ypos) * CWIDTH) <> "." Then
      done
1
      i
    EndIf
    i = i + 1
  EndWhile
If we need to stop the piecemove the box handles to the canvas
If done 1 Then
For 0 to BOXES 1
      v
= Array.GetValue(Array.GetValue(h, -1), i' Array.GetValue(h, -1) = the template name
Math.Floor(v/10)
      Array.SetValue("c", (Math.Floor(v/10) + xpos) + (Math.Remainder(v, 10) + ypos - 1) * CWIDTH, Array.GetValue(h, i))
    EndFor
1 points for every piece successfully dropped
    score
score 1
    PrintScore
' Delete clared lines
    DeleteLines()
  EndIf
EndSub
Sub DeleteLines
  linesCleared = 0
Iterate over each rowstarting from the bottom
For CHEIGHT 1 to 0 Step -1
' Check to see if the whole row is filled
    x = CWIDTH
    While x = CWIDTH
      x = 0
      While x < CWIDTH
        piece = Array.GetValue("c", x + y * CWIDTH)
        If piece = "." then
          x = CWIDTH
        EndIf
        x = x + 1
      EndWhile
if non of them were empty (i."."), then remove the line.
      If
CWIDTH Then
' Delete the line
        For x1 = 0 to CWIDTH - 1
          Shapes.Remove(Array.GetValue("c", x1 + y * CWIDTH))
        EndFor
        linesCleared = linesCleared + 1
Move everything else down one.
        For
y1 y To 1 Step -1
For x1 0 to CWIDTH 1
            piece
= Array.GetValue("c"x1 + (y1 1) * CWIDTH)
            Array.
SetValue("c"x1 y1 CWIDTHpiece)
Shapes.Move(pieceShapes.GetLeft(piece), Shapes.GetTop(piece) + BWIDTH)
          EndFor
        EndFor
      EndIf
    EndWhile
  EndFor
  If
linesCleared 0 Then
    score
score 100 Math.Round(linesCleared 2.15 1)
PrintScore()
  EndIf
EndSub
Sub SetupCanvas
' GraphicsWindow.DrawResizedImage( Flickr.GetRandomPicture( "bricks" ), 0, 0, GraphicsWindow.Width, GraphicsWindow.Height)
  GraphicsWindow.BrushColor = "LightYellow"
  GraphicsWindow.FillRectangle(XOFFSET, YOFFSET, CWIDTH*BWIDTH, CHEIGHT*BWIDTH)
  Program.Delay(200)
  GraphicsWindow.PenWidth = 1
  GraphicsWindow.PenColor = "Pink"
  For x = 0 To CWIDTH-1
    For y = 0 To CHEIGHT-1
      Array.SetValue("c", x + y * CWIDTH, ".") ' "."
indicates spot is free
      GraphicsWindow
.DrawRectangle(XOFFSET BWIDTHYOFFSET BWIDTHBWIDTHBWIDTH)
    EndFor
  EndFor
GraphicsWindow.PenWidth 4
  GraphicsWindow
.PenColor "Black"
GraphicsWindow.DrawLine(XOFFSETYOFFSETXOFFSETYOFFSET CHEIGHT*BWIDTH)
GraphicsWindow.DrawLine(XOFFSET CWIDTH*BWIDTHYOFFSETXOFFSET CWIDTH*BWIDTHYOFFSET CHEIGHT*BWIDTH)
GraphicsWindow.DrawLine(XOFFSETYOFFSET CHEIGHT*BWIDTHXOFFSET CWIDTH*BWIDTHYOFFSET CHEIGHT*BWIDTH)
GraphicsWindow.PenColor "Lime"
GraphicsWindow.DrawLine(XOFFSET 4YOFFSETXOFFSET 4YOFFSET CHEIGHT*BWIDTH 6)
GraphicsWindow.DrawLine(XOFFSET CWIDTH*BWIDTH 4YOFFSETXOFFSET CWIDTH*BWIDTH 4YOFFSET CHEIGHT*BWIDTH 6)
GraphicsWindow.DrawLine(XOFFSET 4YOFFSET CHEIGHT*BWIDTH 4XOFFSET CWIDTH*BWIDTH 4YOFFSET CHEIGHT*BWIDTH 4)
GraphicsWindow.PenColor "Black"
GraphicsWindow.BrushColor "Pink"
XOFFSET PREVIEW_xpos BWIDTH BWIDTH
  y
YOFFSET PREVIEW_ypos BWIDTH BWIDTH
  GraphicsWindow
.FillRectangle(xyBWIDTH 5BWIDTH 6)
GraphicsWindow.DrawRectangle(xyBWIDTH 5BWIDTH 6)
GraphicsWindow.FillRectangle(20190310170)
GraphicsWindow.DrawRectangle(20190310170)
GraphicsWindow.BrushColor "Black"
GraphicsWindow.FontItalic "False"
GraphicsWindow.FontName "Comic Sans MS"
GraphicsWindow.FontSize 16
  GraphicsWindow
.DrawText(x200"Game control keys:")
GraphicsWindow.DrawText(25220"Left Arrow = Move piece left")
GraphicsWindow.DrawText(25240"Right Arrow = Move piece right")
GraphicsWindow.DrawText(25260"Up Arrow = Rotate piece")
GraphicsWindow.DrawText(25280"Down Arrow = Drop piece")
GraphicsWindow.DrawText(x320"Press to stop game")
Program.Delay(200' without this delay, the above text will use the fontsize of the score
  GraphicsWindow.BrushColor = "Black"
  GraphicsWindow.FontName = "Georgia"
  GraphicsWindow.FontItalic = "True"
  GraphicsWindow.FontSize = 36
  GraphicsWindow.DrawText(x - 20, y + 400, "Small Basic Tetris")
  Program.Delay(200) '
without this delaythe above text will use the fontsize of the score
  GraphicsWindow
.FontSize 16
  GraphicsWindow
.DrawText(20440"ver.0.1")
GraphicsWindow.DrawText(20460"http://www.smallbasic.com")
  score = 0
  PrintScore()
EndSub
Sub PrintScore
  GraphicsWindow.PenWidth = 4
  GraphicsWindow.BrushColor = "Pink"
  GraphicsWindow.FillRectangle(500, 65, 153, 50)
  GraphicsWindow.DrawRectangle(500, 65, 153, 50)
  GraphicsWindow.FontItalic = "False"
  GraphicsWindow.FontSize = 32
  GraphicsWindow.FontName = "Impact"
  GraphicsWindow.DrawText(505, 70, Text.Append(Text.GetSubText( "00000000", 0, 8 - Text.GetLength( score ) ), score))
EndSub
Sub SetupTemplates
each piece has 4 boxes.
' the index of each entry within a piece represents the box number (1-4)
the value of each entry represents to box zero-based box coordinate within the piecetens place is xones place y
'_X_
_X_
'_XX
  Array.SetValue("template1", 0, 10)
  Array.SetValue("template1", 1, 11)
  Array.SetValue("template1", 2, 12)
  Array.SetValue("template1", 3, 22)
  Array.SetValue("template1", "color", "Yellow")
  Array.SetValue("template1", "dim", 3)
  Array.SetValue("template1", "pviewx", -12)
  Array.SetValue("template1", "pviewy", 12)
_X_
'_X_
XX_
Array.SetValue("template2"010)
  Array.
SetValue("template2"111)
  Array.
SetValue("template2"212)
  Array.
SetValue("template2"302)
  Array.
SetValue("template2""color""Magenta")
  Array.
SetValue("template2""dim"3)
  Array.
SetValue("template2""pviewx"12)
  Array.
SetValue("template2""pviewy"12)
'_X_
XXX
'_
  Array.SetValue("template3", 0, 10)
  Array.SetValue("template3", 1, 01)
  Array.SetValue("template3", 2, 11)
  Array.SetValue("template3", 3, 21)
  Array.SetValue("template3", "color", "Gray")
  Array.SetValue("template3", "dim", 3)
  Array.SetValue("template3", "pviewx", 0)
  Array.SetValue("template3", "pviewy", 25)
XX_
'XX_
_
Array.SetValue("template4"000)
  Array.
SetValue("template4"110)
  Array.
SetValue("template4"201)
  Array.
SetValue("template4"311)
  Array.
SetValue("template4""color""Cyan")
  Array.
SetValue("template4""dim"2)
  Array.
SetValue("template4""pviewx"12)
  Array.
SetValue("template4""pviewy"25)
'XX_
_XX
'_
  Array.SetValue("template5", 0, 00)
  Array.SetValue("template5", 1, 10)
  Array.SetValue("template5", 2, 11)
  Array.SetValue("template5", 3, 21)
  Array.SetValue("template5", "color", "Green")
  Array.SetValue("template5", "dim", 3)
  Array.SetValue("template5", "pviewx", 0)
  Array.SetValue("template5", "pviewy", 25)
_XX
'XX_
_
Array.SetValue("template6"010)
  Array.
SetValue("template6"120)
  Array.
SetValue("template6"201)
  Array.
SetValue("template6"311)
  Array.
SetValue("template6""color""Blue")
  Array.
SetValue("template6""dim"3)
  Array.
SetValue("template6""pviewx"0)
  Array.
SetValue("template6""pviewy"25)
'_X
_X
'_X
_X
Array.SetValue("template7"010)
  Array.
SetValue("template7"111)
  Array.
SetValue("template7"212)
  Array.
SetValue("template7"313)
  Array.
SetValue("template7""color""Red")
  Array.
SetValue("template7""dim"4)
  Array.
SetValue("template7""pviewx"0)
  Array.
SetValue("template7""pviewy"0)
EndSub
[Image: tetris.png]
mechanical binary calculator https://www.youtube.com/watch?v=NQX6irk11qA
08-16-2020, 03:36 PM (This post was last modified: 09-06-2020 03:00 PM by compsystems.)
RE: Micro$oft SMALLBASIC
Hello.
A proposal
Please, who wants to join the collaborative port of some graphical codes from SB to HpPrime in order to compare the logic and the way of coding between different educational platforms?
another simple game, a ball on a platform, the idea is to keep the ball as long as possible
PHP Code:
GraphicsWindow.Title  "Rocker"
gw 450
gh
400
tx
225
ty
320
score
0
angle
0
ballDirection
= -1
ballSpeed
0.3
acceleration
1.001
power
1.2
gameStarted
"False"
ballX 210
ballY
280
GraphicsWindow
.KeyDown OnKeyDown
CreateUI
gameOver "False"
While gameStarted "False"
Program.Delay(300)
EndWhile
gameStartTime Clock.ElapsedMilliseconds
Shapes
.Remove(directions)
While
gameOver "False"
Shapes.Rotate(paddleangle)
power Math.Abs(angle) / 200
  Shapes
CalculateBallMetrics()
Shapes.Move(ballballXballY)
WriteTime()
Program.Delay(20)
  If
ballX 105 Or ballX 315 Then
    gameOver
"True"
EndIf
EndWhile
GraphicsWindow.ShowMessage("You survived for " timeDisplayText ".""Game Over")
Sub CreateUI
  GraphicsWindow
.CanResize "False"
GraphicsWindow.Width gw
  GraphicsWindow
.Height gh
  GraphicsWindow
.Top = (Desktop.Height gh) / 2
  GraphicsWindow
.Left = (Desktop.Width gw) / 2
  GraphicsWindow
.DrawRectangle(1010430380)
GraphicsWindow.BrushColor "Violet"
tri Shapes.AddTriangle(txtytx 50ty 50tx 50ty 50
GraphicsWindow.BrushColor "Purple"
paddle Shapes.AddRectangle(21010)
Shapes.Move(paddle120310)
GraphicsWindow.BrushColor "Red"
ball Shapes.AddEllipse(3030)
  GraphicsWindow
.FontName "Verdana"
directions Shapes.AddText("Press ENTER to start the game!")
Shapes.Move(directions80150)
GraphicsWindow.BrushColor "Blue"
timeText Shapes.AddText("Time: 00:00")
Shapes.Move(timeText31016)
EndSub
Sub OnKeyDown
If gameStarted "True" Then
If GraphicsWindow.LastKey "Left" Then
      angle
Math.Max(-40angle 1)
    ElseIf
      angle
Math.Min(40angle 1)
    EndIf
  Else
    If
GraphicsWindow.LastKey "Return" Then
      gameStarted
"True"
EndIf
  EndIf
EndSub
Sub CalculateBallMetrics
If ballDirection Math.Abs(angle) = angle Then
    ballSpeed
Math.Min(2ballSpeed power)
  Else
ballSpeed Math.Max(0.1ballSpeed power)
    If
ballSpeed 0.2 Then
      ballDirection
= -ballDirection
      ballSpeed
0.2
EndIf
  EndIf
ballX ballX ballDirection ballSpeed
  deltaX
ballX 210
  deltaY
deltaX Math.Sin(Math.GetRadians(angle))
ballY 280 deltaY
EndSub
Sub WriteTime
  elapsedTime
Clock.ElapsedMilliseconds gameStartTime
  totalSeconds
Math.Round(elapsedTime 1000)
seconds Math.Remainder(totalSeconds60)
minutes Math.Round(totalSeconds 60)
  If (
seconds 10Then
    seconds
Text.Append("0"seconds)
  EndIf
  If (
minutes 10Then
    minutes
Text.Append("0"minutes)
  EndIf
timeDisplayText minutes ":" seconds
  Shapes
.SetText(timeText"Time: " timeDisplayText)
EndSub
SMALL BASIC PRIME IDE 1.1.7.0
https://github.com/litdev1/SB-IDE/releases
