Datamath TI-2500 v2 schematics
08-31-2020, 01:07 PM
I'm trying to repair a Datamath TI-2500 v2, but I can't find schematics anywhere on the web. The main problem is the circuitry on pcb's lower half, composed of discrete components. I'm guessing it's a power supply/regulator circuitry, and perhaps an inverter also, to supply negative voltages to the main IC.
All I have found so far are some high resolution pictures of the PCB (which helped somewhat) but it's not enough. Any help is greatly appreciated, thanks! Eduardo |
