(15C) Backward-Forward Sweep Radial Loadflow
09-02-2020, 12:31 AM (This post was last modified: 09-03-2020 01:42 AM by gerry_in_polo.)
I wrote this program way back in 2014 which computes the voltage profile of a radial electric distribution feeder using the Backward-Forward Sweep Loadflow Method modeling the feeder as a two segment/load node system with one normally closed and normally opened tying disconnect switch. It occupies a mere 123 steps or bytes of memory. The 48G/50g version can model an unlimited number of nodes plus plot the voltage profile.
.pdf  Three Bus Backward-Forward Sweep Program (GVL) - HP 15C.pdf (Size: 23.22 KB / Downloads: 20)
09-02-2020, 10:12 PM
RE: (15C) Backward-Forward Sweep Radial Loadflow
I found the 35s version but not the 50G. Do you plan to post it also?
Thibault - not collector but in love with the few HP models I own - Also musician : http://walruspark.co
09-02-2020, 11:40 PM
(09-02-2020 10:12 PM)pinkman Wrote:  I found the 35s version but not the 50G. Do you plan to post it also?
Planning to do so also. The 50g version is much longer and uses an xyplotting routine I made.
Regards.
